Nvdsosd problem
Could not draw bbox in display when nvdsosd set gpu-id=1.
• Hardware Platform (Jetson / GPU) 2080ti
• DeepStream Version 5.01
• TensorRT Version 7.0.0.-1
• NVIDIA GPU Driver Version (valid for GPU only) 440.95.01
• Issue Type( questions, new requirements, bugs) bugs
gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4 ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt ! nvvideoconvert ! nvdsosd gpu-id=1 ! nveglglessink
docker images = nvcr.io/nvidia/deepstream:5.0.1-20.09-triton
It can work well when you set the gpu-id=0, right?
Yes, I have two 2080ti but nvdsosd works well on gpu-id 0.
Hey customer, I can repro your issue locally. the bbox disappear when setting gpu-id=1 for osd, will check internally and give you reply.
Hey customer, thanks for reporting the issue, we will fix it in later release.
Should be fixed on DS6.0
