Nveglglessink Error on a fresh Deepstream 6.2 dGPU Installation (RTX3060)
• Hardware Platform: dGPU (RTX3060)
• DeepStream Version: 6.2
• TensorRT Version 8.5.2.2
• NVIDIA GPU Driver Version 525.85.12
• Issue Type: bugs
• How to reproduce the issue ? Compile the deepstream-test1 sample app and run it with the default configuration, command can be found below
This is the command I used to run the deepstream-test1 sample app :
$ ./deepstream-test1-app …/…/…/…/samples/streams/sample_720p.h264
Output:
Now playing: ../../../../samples/streams/sample_720p.h264
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:00.366534434  9655 0x55de88993f90 WARN                 nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:00.366581721  9655 0x55de88993f90 WARN                 nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:00.366614354  9655 0x55de88993f90 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
0:00:10.946098385  9655 0x55de88993f90 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1749> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine successfully
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:10.950023909  9655 0x55de88993f90 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running...
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
Frame Number = 0 Number of objects = 6 Vehicle Count = 4 Person Count = 2
0:00:11.157933689  9655 0x55de8836c540 WARN                 nvinfer gstnvinfer.cpp:1984:gst_nvinfer_output_loop:<primary-nvinference-engine> error: Internal data stream error.
0:00:11.157950715  9655 0x55de8836c540 WARN                 nvinfer gstnvinfer.cpp:1984:gst_nvinfer_output_loop:<primary-nvinference-engine> error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(1984): gst_nvinfer_output_loop (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Frame Number = 1 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 2 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 3 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 4 Number of objects = 5 Vehicle Count = 3 Person Count = 2
Frame Number = 5 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 6 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Deleting pipeline
The nveglglessink plugin is giving me the errors, replacing it with a fakesink solves the issue, but I need to actually display the output stream using nveglglessink.
Can you try this blank output -- cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1 · Issue #1 · NVIDIA-AI-IOT/deepstream-retail-analytics · GitHub?
Works like a charm! Thank you!
