Nveglglessink MESA: error: Failed to attach to x11 shm with Docker and Ubuntu 24
• Hardware Platform: RTX 4070
• DeepStream Version: 8.0
• NVIDIA GPU Driver Version: 580.126.09
• Issue Type: bug
• Requirements: Ubuntu 24 host OS, docker, nvidia-container-toolkit
I want to start a deepstream 8.0 pipeline from my host (Ubuntu 24), displaying stream with nveglglessink, but it fails with MESA: error: Failed to attach to x11 shm.
To reproduce the issue, from the terminal, just run:
xhost +
docker container run \
    -it \
    --rm \
    --runtime nvidia \
    -e DISPLAY=$DISPLAY \
    -v /tmp/.X11-unix:/tmp/.X11-unix \
    -v /etc/X11:/etc/X11 \
    nvcr.io/nvidia/deepstream:8.0-triton-multiarch \
    gst-launch-1.0 -e nvvideotestsrc ! nvvideoconvert ! nveglglessink
With 7.1 image it works fine:
    -it \
    --rm \
    --runtime nvidia \
    nvcr.io/nvidia/deepstream:7.1-triton-multiarch \
I know the link FAQ for Deepstream On WSL — DeepStream documentation but I’m using a bare Ubuntu 24 installation, not WSL2.
I really need this to work, because I get the same problem in my devcontainer environment where I develop an application using deepstream pipeline. I think I will stick to 7.1 until there is a working solution, I need to display the output in a window, at least for debugging purpose.
The DeepStream platform compatibility should be followed exactly. Installation — DeepStream documentation. Your driver version should be R570.133.20
You mean each version of DeepStream MUST run with a unique version of the driver??
I will try the driver R570.133.20, but it sounds to me a regression that it works (580.126.09) with 7.1, and not with 8.0…
Yes. The compatibility limitation should be followed.
And you need to make sure the nvidia-container-toolkit has been installed correctly. https://docs.nvidia.com/datacenter/cloud-native/container-toolkit/install-guide.html
OK then I’ll try the driver 570.133.20.
Your command works well with DeepStream 8.0 docker container
OK good news then, thanks for testing it.
I’ll try the driver 570, and if needed I’ll reinstall nvidia-container-toolkit.
What surprises me is that I work without any problem with DS7.1, and wanted to test DS8 on the same machine and got the error.
I cleaned up everything about the container toolkit and the driver, and did a clean install of the 570 driver and the nvidia-container-toolkit.
I still get the same error with DS8 (DS7.1 works fine), I also notices some error about amd (I do have a AMD ryzen CPU):
Setting pipeline to PAUSED ...
_amdgpu_device_initialize: amdgpu_get_auth (1) failed (-1)
amdgpu: amdgpu_device_initialize failed.
libEGL warning: egl: failed to create dri2 screen
Pipeline is PREROLLING ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
Redistribute latency...
New clock: GstSystemClock
With DS7.1 docker image, I get the following output (nothing about AMD here):
libEGL warning: DRI2: could not open /dev/dri/card2 (No such file or directory)
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:01.100215702
Setting pipeline to NULL ...
Freeing pipeline ...
OK I found the problem, I don’t know why in DS8 it happens, maybe because the base image is ubuntu 24 instead of 22.
It seems it detects AMD GPU (integrated with the Ryzen CPU).
If I add --device /dev/dri or --privileged to the docker command, the pipeline works fine.
I guess GStreamer 1.24 works differently compared to 1.20, and that generates this problem.
I found some info at Running ROCm Docker containers — ROCm installation (Linux) .
It has maybe to see with nveglglessink plugin, here is the GST_DEBUG=7 output just before the amd stuff error:
0:00:00.168738517   388 0x5d50abf1c560 DEBUG                GST_BUS gstbus.c:339:gst_bus_post:<bus1> [msg 0x5d50ac37f610] posting on bus have-context message: 0x5d50ac37f610, time 99:99:99.999999999, seq-num 9, element 'eglglessink0', GstMessageHaveContext, context=(GstContext)NULL;
0:00:00.168747825   388 0x5d50abf1c560 DEBUG                GST_BUS gstbus.c:392:gst_bus_post:<bus1> [msg 0x5d50ac37f610] pushing on async queue
0:00:00.168751812   388 0x5d50abf1c560 DEBUG                GST_BUS gstbus.c:395:gst_bus_post:<bus1> [msg 0x5d50ac37f610] pushed on async queue
0:00:00.168755459   388 0x5d50abf1c560 TRACE        GST_REFCOUNTING gstobject.c:266:gst_object_unref:<bus1> 0x5d50ac272e90 unref 3->2
0:00:00.168761551   388 0x5d50abf1c560 TRACE        GST_REFCOUNTING gstminiobject.c:660:gst_mini_object_unref: 0x5d50ac37f610 unref 2->1
0:00:00.168768384   388 0x5d50abf1c560 DEBUG                GST_BUS gstbus.c:381:gst_bus_post:<bus0> [msg 0x5d50ac37f610] dropped
0:00:00.168772010   388 0x5d50abf1c560 TRACE        GST_REFCOUNTING gstobject.c:266:gst_object_unref:<bus0> 0x5d50ac270ff0 unref 5->4
0:00:00.188931073   388 0x5d50abf1c560 INFO             egladaption ext/eglgles/gstegladaptation_egl.c:174:gst_egl_adaptation_init_display:<eglglessink0> System reports supported EGL version v1.5
0:00:00.188950189   388 0x5d50abf1c560 DEBUG            egladaption ext/eglgles/gstegladaptation.c:207:gst_egl_adaptation_fill_supported_fbuffer_configs:<eglglessink0> Building initial list of wanted eglattribs per format
0:00:00.188971449   388 0x5d50abf1c560 TRACE               GST_CAPS gstcaps.c:263:gst_caps_new_empty: created caps 0x5d50ac37b390
0:00:00.188983612   388 0x5d50abf1c560 TRACE               GST_CAPS gstcaps.c:263:gst_caps_new_empty: created caps 0x5d50ac37b310
0:00:00.188994713   388 0x5d50abf1c560 TRACE              structure gststructure.c:292:gst_structure_new_id_empty_with_size: created structure 0x5d50ac39af10
No. It has nothing to do with GStreamer.
It is necessary to share all devices between host and the container with --privileged option.
it’s fine, I’ll do this, but for sure something changed between the 2 images, maybe libdrm or MESA stuff. Anyway it’s working fine now.
