NvEGLRenderer with transparent background
Hi!
I am working on a project that creates two NvEglRenderer objects therefore I have two X windows.
I want to achieve transparency on the upper window. I managed to modify constructor of NvEglRenderer in a way it creates XWindow with transparent background as suggested here.
Window is created successfully and is in fact transparent but the problem occurs in NvEglRenderer::renderThread.
To be more specific here:
renderer->egl_surface = eglCreateWindowSurface(renderer->egl_display, renderer->egl_config,
                (EGLNativeWindowType) renderer->x_window, NULL);
    if (renderer->egl_surface == EGL_NO_SURFACE)
        COMP_ERROR_MSG("Error in creating egl surface " << eglGetError());
        goto error;
eglGetError() throws EGL_BAD_MATCH error. I have tried to modify the egl config but without luck.
Has anyone succeeded in doing something similar?
I am adding the code of modified NvEglRenderer constructor.
NvEglRenderer::NvEglRenderer(const char *name, uint32_t width, uint32_t height,
        uint32_t x_offset, uint32_t y_offset, bool transparent)
        :NvElement(name, valid_fields)
    this->transparent = transparent;
    int depth;
    int screen_num;
    XSetWindowAttributes window_attributes;
    x_window = 0;
    x_display = NULL;
    texture_id = 0;
    gc = NULL;
    fontinfo = NULL;
    egl_surface = EGL_NO_SURFACE;
    egl_context = EGL_NO_CONTEXT;
    egl_display = EGL_NO_DISPLAY;
    egl_config = NULL;
    memset(&last_render_time, 0, sizeof(last_render_time));
    stop_thread = false;
    render_thread = 0;
    render_fd = 0;
    memset(overlay_str, 0, sizeof(overlay_str));
    overlay_str_x_offset = 0;
    overlay_str_y_offset = 0;
    pthread_mutex_init(&render_lock, NULL);
    pthread_cond_init(&render_cond, NULL);
    setFPS(30);
    if (initEgl() < 0)
        COMP_ERROR_MSG("Error getting EGL function addresses");
        goto error;
    x_display = XOpenDisplay(NULL);
    if (NULL == x_display)
        COMP_ERROR_MSG("Error in opening display");
        goto error;
    screen_num = DefaultScreen(x_display);
    if (!width || !height)
        width = DisplayWidth(x_display, screen_num);
        height = DisplayHeight(x_display, screen_num);
        x_offset = 0;
        y_offset = 0;
    COMP_INFO_MSG("Setting Screen width " << width << " height " << height);
    COMP_DEBUG_MSG("Display opened successfully " << (size_t) x_display);
    if (transparent)
        Visual *visual = DefaultVisual(x_display, 0);
        XVisualInfo vinfo;
        XMatchVisualInfo(x_display, DefaultScreen(x_display), 32, TrueColor, &vinfo);
        window_attributes.colormap = XCreateColormap(x_display, DefaultRootWindow(x_display),
                vinfo.visual, AllocNone);
        window_attributes.border_pixel = 0;
        window_attributes.background_pixel = 0x80800000; // Red, semi-transparent
        window_attributes.override_redirect = 1;
        x_window = XCreateWindow(x_display, DefaultRootWindow(x_display), x_offset, y_offset,
                width, height, 0, 32, InputOutput, vinfo.visual,
                CWColormap | CWBorderPixel |  CWBackPixel | CWOverrideRedirect , &window_attributes);
        XSelectInput(x_display, (int32_t) x_window, ExposureMask);
        XMapWindow(x_display, (int32_t) x_window);
        gc = XCreateGC(x_display, x_window, 0, NULL);
    else
        depth = DefaultDepth(x_display, DefaultScreen(x_display));
            BlackPixel(x_display, DefaultScreen(x_display));
                                y_offset, width, height,
                                0,
                                depth, CopyFromParent,
                                CopyFromParent,
                                (CWBackPixel | CWOverrideRedirect),
        XSetForeground(x_display, gc,
                    WhitePixel(x_display, DefaultScreen(x_display)) );
        fontinfo = XLoadQueryFont(x_display, "9x15bold");
    pthread_mutex_lock(&render_lock);
    pthread_create(&render_thread, NULL, renderThread, this);
    pthread_setname_np(render_thread, "EglRenderer");
    pthread_cond_wait(&render_cond, &render_lock);
    pthread_mutex_unlock(&render_lock);
    if(isInError())
        pthread_join(render_thread, NULL);
        goto error;
    COMP_DEBUG_MSG("Renderer started successfully")
    return;
error:
    COMP_ERROR_MSG("Got ERROR closing display");
    is_in_error = 1;
Thank you in advance!
This looks to be about how to use X functions. Since we don’t have much experience in enabling transparent background, this would need other users to share experience.
Another solution is to have single X window and use NvBufSurface APIs to achieve the same behavior. We have NvBufSurfTransformMultiInputBufCompositeBlend() which supports alpha blending. And you can use CUDA programming to access each pixel of NvbufSurface like:
Resources for custom nvivafilter for Jetpack 5.1.1 Jetson NX - #17 by DaneLLL
Hi, @DaneLLL !
Thank you for quick response! I tried using the function you suggested but cannot lose the NvBufSurfTransformError_Invalid_Params error.
I am sending piece of code that I created just to test the function.
Please let me know where am I making mistakes.
NvBufSurface* surfaces[2];
        NvBufSurface* joined_surface;
        // Initialize buffers
        NvBufSurfaceCreateParams createParams;
        createParams.gpuId = 0;
        createParams.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
        createParams.height = SCREEN_SIZE.height();
        createParams.width = SCREEN_SIZE.width();
        createParams.layout = NVBUF_LAYOUT_PITCH;
        createParams.isContiguous = false;
        createParams.memType = NVBUF_MEM_DEFAULT;
        if(NvBufSurfaceCreate(&surfaces[0],1,&createParams) != 0) printf("Cannot create BufSurface\n");
        if(NvBufSurfaceCreate(&surfaces[1],1,&createParams) != 0) printf("Cannot create BufSurface\n");
        if(NvBufSurfaceCreate(&joined_surface,1,&createParams) != 0) printf("Cannot create BufSurface\n");
        NvBufSurfTransformCompositeBlendParamsEx para;
        float alpha[] = {0.5f, 0.5f};
        NvBufSurfTransform_Inter filters[] = {NvBufSurfTransformInter_Default};
        NvBufSurfTransformRect rects[2];
        NvBufSurfTransform_ColorParams color_bg = {1.0,1.0,0.0,1.0};
        rects[0].height = 1080;
        rects[0].width = 1920;
        rects[0].top = 0;
        rects[0].left = 0;
        rects[1].height = 1080;
        rects[1].width = 1920;
        rects[1].top = 0;
        rects[1].left = 0;
        para.alpha = alpha;
        para.composite_blend_filter = filters;
        para.dst_comp_rect = rects; // Take only the first one
        para.src_comp_rect = rects;
        para.params.color_bg = &color_bg;
        para.params.composite_blend_flag = 0;
        para.params.composite_blend_filter = NvBufSurfTransformInter_Default;
        para.params.input_buf_count = 2;
        para.params.perform_blending = 0;
        int res = NvBufSurfTransformMultiInputBufCompositeBlend(surfaces, joined_surface, &para);
Sorry for the late response.
The source code of nvcompositor plugin is public. You may also refer to it:
Jetson Linux | NVIDIA Developer
Driver Package (BSP) Sources
