NVENC and NVDEC work on only one GPU with Multi-GPU setups with NVIDIA Container Toolkit in Driver >=565
The above are critical issues where NVENC and NVDEC work on only one GPU with Multi-GPU setups with NVIDIA Container Toolkit in driver versions >565, which is >=570.
This is in relation to NVENC crashing (due to not finding a CUDA device) when using multiple NVIDIA GPUs while trying to use any index other than ‘0’. Many efforts tried to only expose devices using NVIDIA_VISIBLE_DEVICES envvar and assigning them using index or GPU-UUID.
Only one GPU works (it may be the first GPU, last GPU, or anything in between), and everything else fails in FFmpeg:
[h264_nvenc @ 0x] OpenEncodeSessionEx failed: unsupported device (2): (no details)
[h264_nvenc @ 0x] No capable devices found
Moreover, GStreamer also fails in a similar way when FFmpeg fails:
nvh264encoder gstnvh264encoder.cpp:2158:gst_nv_h264_encoder_register_cuda:<cudacontext0> Failed to open session
nvh265encoder gstnvh265encoder.cpp:2196:gst_nv_h265_encoder_register_cuda:<cudacontext0> Failed to open session
nvenc gstnvenc.c:685:gst_nv_enc_register: NvEncOpenEncodeSessionEx failed: codec h264, device 0, error code 2
nvenc gstnvenc.c:685:gst_nv_enc_register: NvEncOpenEncodeSessionEx failed: codec h265, device 0, error code 2
The above is on driver version 580.82.07 with five NVIDIA Titan Xp GPUs.
Driver versions 565 or 550 work fine, but this is a regression of the driver version 570 or higher; therefore, I am bringing this up in the forum to the driver team.
This is widely known to happen in Kubernetes, but it may also happen in Docker.
CC @amrits @generix
We are also closely monitoring this issue. Based on our test, ffmpeg NVENC functionality within K8S pods is working well on Tesla T4 nodes with multiple GPU cards. Since issue NVENC Fails in Kubernetes Pods on all but the last GPU with Driver 570.x or 580.x · Issue #1249 · NVIDIA/nvidia-container-toolkit · GitHub have indicated stable performance on V100 GPUs, and considering the current findings, we suspect there might be some driver-level issues affecting NVENC support for the GeForce series—particularly models like the 3060, 4090, and 5090. We’re continuing to look into this and will provide updates as we learn more.
It has been confirmed that driver version 565.57.01 does not have this issue, but both the 570 and 580 series are affected. What is the current status regarding this problem?
@ktsong I have confirmed that the 580 driver series have the issue on Nvidia RTX 5070 Ti GPUs. This forces us to downgrade drivers and OS. When should we expect a fix?
Is anyone looking into this issue? We are also forced to use older drivers which blocks the use of our newly purchased RTX 5090 GPUs in our cluster …
I’ve figured out why it doesn’t work. It has nothing to do with the mismatch of /dev/nvidiaX between container and host.
When NVENC is initialized, NVENC’s user‑space stack (libnvcuvid/libnvidia-encode) queries the NVIDIA Resource Manager via /dev/nvidiactl and gets an “attached GPU IDs” list (NV0000_CTRL_CMD_GPU_GET_ATTACHED_IDS, cmd 0x201) that includes all host GPUs, even inside a 1‑GPU pod.
When that list contains multiple GPUs, the NVENC open path takes a multi‑GPU/peer‑init branch and tries to touch the other GPU’s device node (/dev/nvidiaY), which is not mounted in the pod.
That peer‑init step fails, so the code bails out before class enumeration (0x00800201) and before allocating the required RM object (class 0xC661), returning NV_ENC_ERR_UNSUPPORTED_DEVICE even though the target GPU itself is fine.
The issue needs to be fixed by Nvidia.
@amrits @generix Can a ticket be opened in NVIDIA regarding the above for 590, 580, and 570 (all currently supported driver branches affected)?
I can also confirm this problem. This issue currently prohibits us from bumping drivers in our cluster and start using 5090s - would be great if this is fixed ASAP!
I did more investigation, figured out the internal logic.
  1. libnvidia-encode.so calls libnvcuvid.so to setup/init GPUs
  2. libnvcuvid.so communicates with RM via /dev/nvidiactl, and it can see all GPUs
  3. When there are multiple GPUs available, it picks one as “primary” GPU. That’s the GPU with the “lexicographically smallest” uuid. Even if it can get which GPU is really available from libcuda.so
So, when you have multiple GPUs in the host. Only the container which has the “smallest” GPU uuid works.
It doesn’t mean in the host NVENC can only works on one GPU. That “primary” GPU setup is only during GPU init phase. If that phase passes, real nvenc coding work can be done on non primary GPU.
I’m not sure if it’s intended, since it has been long time no fix from Nvidia.
@aplattner @amrits @generix
Could the driver team please forward the request below to backport the 610 fix regarding NVENC in containers to 595 and 580? 580 is the last long-term supported version for Maxwell, Pascal, and Volta, and we cannot use earlier drivers due to likely vulnerabilities which will not be fixed.
https://github.com/NVIDIA/k8s-device-plugin/issues/1282#issuecomment-4653345876
https://github.com/NVIDIA/k8s-device-plugin/issues/1282#issuecomment-4655450391
The LD_PRELOAD solution is a neat trick. But the suggestion that container-toolkit should filter the library call is an unlikely path forward as container-toolkit shouldn’t interfere with driver’s behaviour (however wrong).
The fix certainly belongs in the driver in terms of listing the IDs explicitly exposed to the environment.
610.x versions seem to have the fix. While I need to verify the 610.x fix, I am inclined to mark this issue as ‘Closed’ with the interpretation that it “won’t be fixed in container-toolkit”.
Users who are still facing the issue have a few options:
Downgrade the driver to 565.x and prior
Use LD_PRELOAD to intercept the ResourceManager call (details in this comment)
use NVIDIA_VISIBLE_DEVICES env var (boo :))
Use 610.x drivers (not tested yet)
Please re-open the issue if anyone feels even slightly otherwise.
Is it possible to backport the fixes to 595 and 580? Most importantly, 580 is the only long-term supported driver for Pascal and Maxwell GPUs.
That’s not in our control as we are not a part of the driver team. Our team’s work is focused on GPU enablement in containers and Kubernetes The NVIDIA dev forums will is the right place to make this request.
I’ve been testing the 610.43.03 drivers with a machine using 3 RTX 2070 and I can tell the NVENC issue described above is not fixed at all. Only the container using the GPU with the smaller UUID is able to use NVENC.
We’re currently experiencing the same problem under 580.126.20, however the issue only happened on our 8x 4090 GPUs machine, another 8x PRO 5000 machine works fine. Seems matches the conclusion above. We tried to set NVIDIA_VISIBLE_DEVICES value: “all” to partially solved our specific problem(Isaac sim WebRTC disconnect), but it will lead to the graphics become very noisy.
I updated my drivers to the newly released 610.57.04 and the NVENC issue described above is still present.
