How Rate Control Mode in nvenc works? Will nvenc remove frames, i.e., for example, in case of 100 input frames may there be only 99 frames in output?
Somewhere I read that encoding in nvenc is similar to x264. But x264 rate control may remove frames, and it is bad.
And the second question:
what is the difference between
8 : Two Pass Frame Quality
16 : Two Pass Frame Size Cap
32 : Two Pass VBR
