I am testing NVENC SDK 4.0 in GeForce GTX 760 and GTX 680. When I run nvEncodeApp sample in Windows 7-64 bit and it works perfectly, so the hardware seems to work correctly.
But when I try to run the same code in Linux (Ubuntu 14.04 & Debian wheezy) it fails when calling NvEncInitializeEncoder. This call returns error code 8 (NV_ENC_ERR_INVALID_PARAM).
jtaibo@perkele:~/nvenc_sdk_4.0/Samples/nvEncodeApp$ sh ./1080p_heavyhand_3sec.sh
>> GetNumberEncoders() has detected 1 CUDA capable GPU device(s) <<
[ GPU #0 - < GeForce GTX 680 > has Compute SM 3.0, NVENC Available ]
>> InitCUDA() has detected 1 CUDA capable GPU device(s)<<
[ GPU #0 - < GeForce GTX 680 > has Compute SM 3.0, Available NVENC ]
>> Select GPU #0 - < GeForce GTX 680 > supports SM 3.0 and NVENC
nvEncoder Error: NVENC H.264 encoder initialization failure! Check input params!
[b]Is NVENC SDK for Linux really supported in GeForce cards ?
