We are using NVIDIA RTX A2000 12 GB model in a Television Broadcast Playout Server, to produce H.264 Video Streams.
We are getting only 1080Progressive Outputs with this card, as our Playout software team have tested.
Would request your support to achieve the 1080i H.H264 Video Streams with our playout software.
Kindly advise us with required driver version or with F/w to apply on the NVIDIA RTX A2000 12 GB.
Thanks for your kind reply, kindly share the Channel Partner contact details in India.
We would like to check with you on the RTX A2000, does it support interlaced Video Stream Encoding.
Looking forward your kind support extended, so that we may reach a solution if possible with RTX A2000 or with other suggested models.
We looking forward your kind update in this post, if you would have examined the situation of interlaced Video Encoding with H.264 using RTX A2000.
With respect to capabilities, you will find all the suported video format in our NVDEC/NVENC GPU matrix. The support for interlaced video encoding was discontinued already with the Turing generation of GPUs.
