Hi everyone,
I’m trying to capture my desktop using Desktop Duplication API, encode the D3DTexture2D using NVENC and send it over the local network. The performance of everything is very high until I reach the part where we need to lock the bitstream and extract the data. Below is the code used:
NV_ENC_LOCK_BITSTREAM lockBitstreamData = { NV_ENC_LOCK_BITSTREAM_VER };
lockBitstreamData.outputBitstream = vOutputBuffer[m_iGot % m_nEncoderBuffer];
lockBitstreamData.doNotWait = false;
auto starti = std::chrono::system_clock::now();
NVENC_API_CALL(m_nvenc.nvEncLockBitstream(m_hEncoder, &lockBitstreamData));
auto end = std::chrono::system_clock::now();
std::chrono::duration<double> elapsed_seconds = end - starti;
std::time_t end_time = std::chrono::system_clock::to_time_t(end);
std::cout << "finished computation at " << std::ctime(&end_time)
<< "elapsed time: " << elapsed_seconds.count() << "s\n";
uint8_t *pData = (uint8_t *)lockBitstreamData.bitstreamBufferPtr;
if (vPacket.size() < i + 1)
vPacket.push_back(std::vector<uint8_t>());
vPacket[i].clear();
vPacket[i].insert(vPacket[i].end(), &pData[0], &pData[lockBitstreamData.bitstreamSizeInBytes]);
i++;
NVENC_API_CALL(m_nvenc.nvEncUnlockBitstream(m_hEncoder, lockBitstreamData.outputBitstream));
The “NVENC_API_CALL(m_nvenc.nvEncLockBitstream(m_hEncoder, &lockBitstreamData));” takes anything from under 10ms when under desktop at low load to an average of 90ms when I run a game in full screen under heavy load. Our constraints require “real-time” 60fps so anything over 16ms is too high. Is there a way to get that down?
