Hi all,
We are working on an application for rendering video and it has been working for years now. We use NVidia encoding api 10.0 and after an update to a new driver around november/december openening an encoding session fails. Strange thing is that the same thing happens with the example application provided in the Video Codec SDK and I can’t figure out what’s the cause of this error.
What happens is that an error gets thrown in the following constructor:
NvEncoder::NvEncoder(NV_ENC_DEVICE_TYPE eDeviceType, void *pDevice, uint32_t nWidth, uint32_t nHeight, NV_ENC_BUFFER_FORMAT eBufferFormat,
uint32_t nExtraOutputDelay, bool bMotionEstimationOnly, bool bOutputInVideoMemory) :
m_pDevice(pDevice),
m_eDeviceType(eDeviceType),
m_nWidth(nWidth),
m_nHeight(nHeight),
m_nMaxEncodeWidth(nWidth),
m_nMaxEncodeHeight(nHeight),
m_eBufferFormat(eBufferFormat),
m_bMotionEstimationOnly(bMotionEstimationOnly),
m_bOutputInVideoMemory(bOutputInVideoMemory),
m_nExtraOutputDelay(nExtraOutputDelay),
m_hEncoder(nullptr)
LoadNvEncApi();
if (!m_nvenc.nvEncOpenEncodeSession)
m_nEncoderBuffer = 0;
NVENC_THROW_ERROR("EncodeAPI not found", NV_ENC_ERR_NO_ENCODE_DEVICE);
NV_ENC_OPEN_ENCODE_SESSION_EX_PARAMS encodeSessionExParams = { NV_ENC_OPEN_ENCODE_SESSION_EX_PARAMS_VER };
encodeSessionExParams.device = m_pDevice;
encodeSessionExParams.deviceType = NV_ENC_DEVICE_TYPE_CUDA;// m_eDeviceType;
encodeSessionExParams.apiVersion = NVENCAPI_VERSION;
void *hEncoder = NULL;
NVENC_API_CALL(m_nvenc.nvEncOpenEncodeSessionEx(&encodeSessionExParams, &hEncoder));
m_hEncoder = hEncoder;
Calling NVENC_API_CALL(m_nvenc.nvEncOpenEncodeSessionEx(&encodeSessionExParams, &hEncoder)); will result in an exception with NV_ENC_ERR_GENERIC as error code.
I’ve also tried the 12.1 SDK resulting in the same issue. We are using NvEncoderD3D11.cpp as basis for our encoder code.
I’ve tested it with Windows 10 and 11 using different graphical cards like:
GTX 1060 Super
RTX 5000
RTX 4060
GTX 1080
Downgrading the driver makes the encoder work again.
Can anyone help me finding out whats going wrong? What can I do to solve this?
