Nvfortran bug: two different-named entities are mixed up
In the program below, the entities nona (scalar dummy argument) and nona2 (external procedure) are mixed up and a bogus error is issued:
$ nvfortran -c a.f90
NVFORTRAN-S-0134-Illegal attribute - intent specified for dummy subprogram argument nona (a.f90: 12)
  0 inform,   0 warnings,   1 severes, 0 fatal for test
The error is bogus because nona was never declared as a subprogram (nona2 is), and it goes away if procedure(foo) is changed to external, or if nona2 is renamed to nona_2 or nona2a.
module bah
abstract interface
  subroutine foo()
  end subroutine foo
end interface
end module bah
subroutine test(nona)
logical, intent(in) :: nona
procedure(foo) :: nona2
write(6,*) nona
call nona2()
end subroutine test
$ nvfortran --version
nvfortran 20.9-0 LLVM 64-bit target on x86-64 Linux -tp sandybridge
NVIDIA Compilers and Tools
Copyright (c) 2020, NVIDIA CORPORATION.  All rights reserved.
Thanks Jellby. I was able to recreate the error here and have filed a problem report, TPR #32373.
Besides make it external, another work around is to add a specific interface. Something like:
module bah
abstract interface
subroutine foo()
end subroutine foo
end interface
end module bah
use bah
interface
subroutine nona2()
end subroutine
end interface
write(6,*) nona
call nona2()
end subroutine test
-Mat
Yeah, well… Using procedure(foo) was a way to avoid having to write an explicit interface (especially when there are many subroutines that share the same one).
By the way, I just realized I was missing the use bah part, although the error is the same. Make it like this:
module bah
abstract interface
  subroutine foo()
  end subroutine foo
end interface
end module bah
implicit none
use bah, only: foo
write(6,*) nona
call nona2()
end subroutine test
Now the other question (bug?) is why does it work (after renaming nona2) without using the module?
No idea, but our compiler engineers will investigate.
Hi Jellby,
In 22.11, we now catch the error in the initial program and are able to compile the second (once the ‘use’ and ‘implicit none’ ordering is fixed).
% nvfortran -c test.f90 -V22.11
NVFORTRAN-S-1257-Interface foo must be declared. (test.f90: 14)
% nvfortran -c test2.f90 -V22.11
-Mat
