Nvfortran bug with character in class(*) subroutine
I have a problem with the newly released nvfortran 24.7. Take the following example:
PROGRAM main
    IMPLICIT NONE
    CHARACTER(len=10) :: str1
    CHARACTER(len=:), ALLOCATABLE :: str2
    CHARACTER(len=10) :: str3(2)
    CALL test_class(str1)
    CALL test_char(str1)
    ALLOCATE(CHARACTER(len=10) :: str2)
    CALL test_class(str2)
    CALL test_char(str2)
    CALL test_class(str3(1))
    CALL test_char(str3(1))
CONTAINS
    SUBROUTINE test_class(arg)
        ! Subroutine arguments
        CLASS(*), INTENT(inout) :: arg
        SELECT TYPE (arg)
        TYPE IS (CHARACTER(len=*))
            WRITE(*, *) "Length: ", LEN(arg)
        CLASS DEFAULT
            WRITE(*, *) "Not a character"
        END SELECT
    END SUBROUTINE test_class
    SUBROUTINE test_char(arg)
        CHARACTER(len=*), INTENT(inout) :: arg
    END SUBROUTINE test_char
END PROGRAM main
All compilers I tried (gfortran, ifort, ifx, nagfor) besides nvfortran works as expected and give the same result:
 Length:           10
 Length:           10
 Length:           10
 Length:           10
 Length:           10
 Length:           10
With nvfortran there seems to be a bug when an element of the the character string array str3 is passed in the CLASS(*) argument of test_class:
 Length:            10
 Length:            10
 Length:            10
 Length:            10
 Length:       4198976
 Length:            10
The exact value printed on the second last line vary from run to run and seems to be arbitrary.
This seems to be a compiler bug in nvfortran. Any comments? Thanks in advance.
Hi Hakostra! I’ll take a look and open an engineering report if I’m able to determine that this is a compiler issue. Thanks for letting us know!
Hey Hakostra - I have reported the issue to engineering as TPR#36126. When I hear back about a fix, I’ll let you know! Thanks for letting us know about the issue. And please feel free to let us know about any other issues you run into.
Cheers,
Seth.
Thanks for looking into this! flang-new (compiled from LLVM main repo today) can be added to the list of compilers that treat this case correctly.
Engineering has notified me that we have fixed this in the latest release!
