NVFortran: C preprocessor bug
Hello!
I have tried to compile the following code (fortran-77):
#define _SAD_ 4
      print *,
     $(4.eq._SAD_)
      end
Compilation options:
nvfortran -Mpreprocess test.f -E
That’s prints to stdout the following result:
# 1 "test.f"
# 2 "test.f"
      print *,
     $(4.eq._SAD_)
      end
So, _SAD_ macro was not expanded. At the same time, if one remove round brackets, the output will be the following:
$ nvfortran -Mpreprocess test.f -E
# 1 "test.f"
# 2 "test.f"
      print *,
     $4.eq.4
      end
That is expected.
NVFortran version:
$ nvfortran --version
nvfortran 24.3-0 64-bit target on x86-64 Linux -tp znver2
NVIDIA Compilers and Tools
Copyright (c) 2024, NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
If you can, add a space between the “.” and “SAD” so it’s seen as a unique token.
Preprocessing is not part of the Fortran standard so each compiler may have slightly different implementations. Ours is similar to the “cpp” C preprocessor, which gives the same output:
% cpp test.F
# 0 "test.F"
# 0 "<built-in>"
# 0 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 0 "<command-line>" 2
# 1 "test.F"
      print *,
     $(4.eq._SAD_)
      end
Thank you! This is a solution for such cases. Luckily, it is only one place in our codebase.
