Nvfortran compile issues with UDDTIO
We are trying to add UDDTIO to our MAS ( MAS/src at main · predsci/MAS · GitHub ) code. Below, I have included a small reproducing example that demonstrates the issue we are encountering.
When compiling with NVFORTRAN, we receive the following errors:
NVFORTRAN-S-0084-Illegal use of symbol r_profile (test_heatsource_uddtio.f90: 65)
0 inform, 0 warnings, 4 severes, 0 fatal for test_heatsource_uddtio
The code compiles and runs correctly with gfortran, so we are unsure whether we are using UDDTIO incorrectly or if this may be a compiler-specific issue.
Any guidance or clarification would be greatly appreciated.
Best,
Miko Stulajter
Compile:
nvfortran -O3 test_heatsource_uddtio.f90 -o test_heatsource_uddtio
Run:
./test
Input file:
&test_nml
  heatsource(2)%r_profile%active = .true.
Fortran code:
module profile_def
  implicit none
  type :: profile
    logical :: active=.false.
    real :: f(3)=1.0
    real :: x(2)=(/-1.e20,1.e20/)
    real :: w(2)=1.0
  end type
  interface read(formatted)
    module procedure read_profile_formatted
  end interface
  interface write(formatted)
    module procedure write_profile_formatted
  end interface
contains
  subroutine read_profile_formatted (dtv, unit, iotype, v_list, iostat, iomsg)
    class(profile), intent(inout) :: dtv
    integer, intent(in) :: unit
    character(*), intent(in) :: iotype
    integer, intent(in) :: v_list(:)
    integer, intent(out) :: iostat
    character(*), intent(inout) :: iomsg
    iostat = 0
    iomsg = ' '
    read (unit, *, iostat=iostat, iomsg=iomsg) dtv%active, dtv%f, dtv%x, dtv%w
  end subroutine read_profile_formatted
  subroutine write_profile_formatted (dtv, unit, iotype, v_list, iostat, iomsg)
    class(profile), intent(in) :: dtv
    iostat = 0
    iomsg = ' '
    write (unit, *, iostat=iostat, iomsg=iomsg) dtv%active, dtv%f, dtv%x, dtv%w
  end subroutine write_profile_formatted
end module
module heat_source_module
  use profile_def
  implicit none
  type :: heat_source
    type(profile) :: r_profile
  end type
  type(heat_source), dimension(2) :: heatsource
end module
program test_heatsource_uddtio
  use heat_source_module
  implicit none
  integer :: iostat
  character(256) :: iomsg
  namelist /test_nml/ heatsource
  open(unit=10, file='test_input.in', status='old', iostat=iostat)
  read(unit=10, nml=test_nml, iostat=iostat, iomsg=iomsg)
  close(unit=10)
  open(unit=11, file='test_output.out', status='replace', iostat=iostat)
  write(unit=11, nml=test_nml, iostat=iostat, iomsg=iomsg)
  close(unit=11)
end program
Hi Miko,
I’m not too familiar with UDDTIO myself, so not sure if this is a compiler bug, unsupported feature, or an issue with the code. The person I normally ask these types of question is out for the holidays, so don’t have an answer.
Though given the code works with gfortran and our upcoming LLVM based nvfortran, I’m leaning towards compiler issue or unsupported feature. I filed a report, TPR #38094, and sent it to engineering.
Once I hear back, I’ll let you know.
-Mat
Hi Miko,
Engineering let me know that this one will be difficult to get to work in our current PGI based nvfortran so we’ll need to wait for the LLVM base nvfortran’s release.
However, then did provide a work around by creating wrappers for the I/O as shown in the following example:
module profile_def
  implicit none
  type :: profile
    real :: f(3)=1.0
    real :: w(2)=1.0
    contains
  end type
  type :: heat_source
  end type
    module procedure read_heat_source_formatted
  end interface
    module procedure write_heat_source_formatted
  end interface
contains
    iostat = 0
    iomsg = ' '
    iostat = 0
    iomsg = ' '
  subroutine read_heat_source_formatted (dtv, unit, iotype, v_list, iostat, iomsg)
    class(heat_source), intent(inout) :: dtv
    call read_profile_formatted(dtv%r_profile, unit, iotype, v_list, iostat, iomsg)
  end subroutine read_heat_source_formatted
  subroutine write_heat_source_formatted (dtv, unit, iotype, v_list, iostat, iomsg)
    class(heat_source), intent(in) :: dtv
    call write_profile_formatted(dtv%r_profile, unit, iotype, v_list, iostat, iomsg)
  end subroutine write_heat_source_formatted
end module
  use profile_def
  implicit none
!  type :: heat_source
!    type(profile) :: r_profile
!  end type
end module
  implicit none
  integer :: iostat
  close(unit=10)
  close(unit=11)
end program
-Mat
