I compiled my code with nvfortran. I used mpi run, but got an error:
“Caught signal 11 (Segmentation fault: address not mapped to object at address 0x5800005b)”
And then it shows a bunch of lib files in different folders (which I have exported a path too).
Finally it shows this:
“Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 2 with PID 0 on node laptop exited on signal 11 (Segmentation fault).”
What does this mean and how can I fix it?
