NVFORTRAN-F-0004-Corrupt or Old Module file netcdf_nc_data.mod
Good day,
I am trying to build netcdf-fortran by following the steps here (Full WRF and WPS Installation Example (GNU) | WRF & MPAS-A Support Forum). I have set my CC, CXX, FC, and F77 to pgcc, pgc++, pgfortran, and pgfortran, respectively. However, make returns with this error,
NVFORTRAN-F-0004-Corrupt or Old Module file netcdf_nc_data.mod (nf_nc4.f90: 1980)
NVFORTRAN/x86-64 Linux 23.3-0: compilation aborted
make[2]: *** [Makefile:773: nf_nc4.lo] Error 1
make[2]: *** Waiting for unfinished jobs…
make[2]: *** [Makefile:773: nf_fortv2.lo] Error 1
I have read that this happens when the module was built with a different compiler, which I think is not the case here since I have set my compilers to PGFs at the very beginning, and netcdf_nc_data.mod seems to be a product of make (please refer to the output of make at the very end). What could be causing this?
Note: I have successfully built this before with GNU compilers; I have chosen to recompile this with PGI compilers because I will be referring to this build with other PGI-compiled programs.
Output of Make:
Making all in libsrc
make[1]: Entering directory ‘/home/essmsd/Documents/Build_WRF/netcdf-fortran-4.5.2/libsrc’
make[1]: Nothing to be done for ‘all’.
make[1]: Leaving directory ‘/home/essmsd/Documents/Build_WRF/netcdf-fortran-4.5.2/libsrc’
Making all in fortran
make[1]: Entering directory ‘/home/essmsd/Documents/Build_WRF/netcdf-fortran-4.5.2/fortran’
pgfortran -I. -m64 -c -o typeSizes.o typeSizes.f90
pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o module_netcdf_nc_data.o module_netcdf_nc_data.F90
echo ‘! NetCDF-3.’ > netcdf.inc
cat …/fortran/netcdf3.inc >> netcdf.inc
echo >> netcdf.inc
echo ‘! NetCDF-4.’ >> netcdf.inc
cat …/fortran/netcdf4.inc >> netcdf.inc
echo >> netcdf.inc
echo ‘! NetCDF-2.’ >> netcdf.inc
cat …/fortran/netcdf2.inc >> netcdf.inc
echo >> netcdf.inc
echo ‘! This is to turn on netCDF internal logging.’ >> netcdf.inc
echo ’ integer nf_set_log_level’ >> netcdf.inc
echo ’ external nf_set_log_level’ >> netcdf.inc
pgfortran -I. -m64 -c -o netcdf4.o netcdf4.f90
pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o module_netcdf_nf_data.o module_netcdf_nf_data.F90
pgfortran -I. -m64 -c -o module_netcdf_nc_interfaces.o module_netcdf_nc_interfaces.f90
pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o module_netcdf_nf_interfaces.o module_netcdf_nf_interfaces.F90
pgfortran -I. -m64 -c -o module_netcdf_fortv2_c_interfaces.o module_netcdf_fortv2_c_interfaces.f90
pgfortran -I. -m64 -c -o module_netcdf4_nc_interfaces.o module_netcdf4_nc_interfaces.f90
pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o module_netcdf4_nf_interfaces.o module_netcdf4_nf_interfaces.F90
pgfortran -I. -m64 -c -o module_netcdf4_f03.o module_netcdf4_f03.f90
make all-am
make[2]: Entering directory ‘/home/essmsd/Documents/Build_WRF/netcdf-fortran-4.5.2/fortran’
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o nf_attio.lo nf_attio.F90
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o nf_control.lo nf_control.F90
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -I. -m64 -c -o nf_dim.lo nf_dim.f90
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -I. -m64 -c -o nf_misc.lo nf_misc.f90
libtool: compile: pgfortran -I. -m64 -c nf_misc.f90 -fpic -o .libs/nf_misc.o
libtool: compile: pgfortran -I. -m64 -c nf_dim.f90 -fpic -o .libs/nf_dim.o
libtool: compile: pgfortran -I. -m64 -c nf_misc.f90 -o nf_misc.o >/dev/null 2>&1
libtool: compile: pgfortran -I. -m64 -c nf_dim.f90 -o nf_dim.o >/dev/null 2>&1
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -I. -m64 -c -o nf_genatt.lo nf_genatt.f90
libtool: compile: pgfortran -I. -m64 -c nf_genatt.f90 -fpic -o .libs/nf_genatt.o
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_control.F90 -fpic -o .libs/nf_control.o
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte "-DNF_INT2_T=integer
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_attio.F90 -fpic -o .libs/nf_attio.o
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -I. -m64 -c -o nf_geninq.lo nf_geninq.f90
libtool: compile: pgfortran -I. -m64 -c nf_geninq.f90 -fpic -o .libs/nf_geninq.o
libtool: compile: pgfortran -I. -m64 -c nf_genatt.f90 -o nf_genatt.o >/dev/null 2>&1
libtool: compile: pgfortran -I. -m64 -c nf_geninq.f90 -o nf_geninq.o >/dev/null 2>&1
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_attio.F90 -o nf_attio.o >/dev/null 2>&1
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_control.F90 -o nf_control.o >/dev/null 2>&1
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -I. -m64 -c -o nf_genvar.lo nf_genvar.f90
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o nf_vario.lo nf_vario.F90
libtool: compile: pgfortran -I. -m64 -c nf_genvar.f90 -fpic -o .libs/nf_genvar.o
libtool: compile: pgfortran -I. -m64 -c nf_genvar.f90 -o nf_genvar.o >/dev/null 2>&1
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o nf_var1io.lo nf_var1io.F90
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o nf_varaio.lo nf_varaio.F90
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_vario.F90 -fpic -o .libs/nf_vario.o
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o nf_varmio.lo nf_varmio.F90
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_vario.F90 -o nf_vario.o >/dev/null 2>&1
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_var1io.F90 -fpic -o .libs/nf_var1io.o
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_varaio.F90 -fpic -o .libs/nf_varaio.o
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_varmio.F90 -fpic -o .libs/nf_varmio.o
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o nf_varsio.lo nf_varsio.F90
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_var1io.F90 -o nf_var1io.o >/dev/null 2>&1
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_varaio.F90 -o nf_varaio.o >/dev/null 2>&1
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_varsio.F90 -fpic -o .libs/nf_varsio.o
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_varmio.F90 -o nf_varmio.o >/dev/null 2>&1
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o nf_logging.lo nf_logging.F90
source=‘nf_v2compat.c’ object=‘nf_v2compat.lo’ libtool=yes
DEPDIR=.deps depmode=tcc /bin/bash …/depcomp
/bin/bash …/libtool --tag=CC --mode=compile pgcc -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -g -O2 -DLONGLONG_IS_LONG -c -o nf_v2compat.lo nf_v2compat.c
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_logging.F90 -fpic -o .libs/nf_logging.o
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_varsio.F90 -o nf_varsio.o >/dev/null 2>&1
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c nf_logging.F90 -o nf_logging.o >/dev/null 2>&1
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -I. -m64 -c -o nf_fortv2.lo nf_fortv2.f90
libtool: compile: pgfortran -I. -m64 -c nf_fortv2.f90 -fpic -o .libs/nf_fortv2.o
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -I. -m64 -c -o nf_nc.lo nf_nc.f90
libtool: compile: pgcc -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer*2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -g -O2 -DLONGLONG_IS_LONG -c nf_v2compat.c -MD -MF .deps/nf_v2compat.TPlo -fPIC -DPIC -o .libs/nf_v2compat.o
libtool: compile: pgfortran -I. -m64 -c nf_nc.f90 -fpic -o .libs/nf_nc.o
“nf_v2compat.c”, line 129: warning: integer conversion resulted in a change of sign [integer_sign_change]
size = -1;
Remark: individual warnings can be suppressed with “–diag_suppress ”
libtool: compile: pgfortran -I. -m64 -c nf_nc.f90 -o nf_nc.o >/dev/null 2>&1
source=‘nf_lib.c’ object=‘nf_lib.lo’ libtool=yes
/bin/bash …/libtool --tag=CC --mode=compile pgcc -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -g -O2 -DLONGLONG_IS_LONG -c -o nf_lib.lo nf_lib.c
libtool: compile: pgcc -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -g -O2 -DLONGLONG_IS_LONG -c nf_v2compat.c -MD -MF .deps/nf_v2compat.TPlo -o nf_v2compat.o >/dev/null 2>&1
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -I. -m64 -c -o nf_nc4.lo nf_nc4.f90
libtool: compile: pgfortran -I. -m64 -c nf_nc4.f90 -fpic -o .libs/nf_nc4.o
libtool: compile: pgcc -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte "-DNF_INT2_T=integer
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -g -O2 -DLONGLONG_IS_LONG -c nf_lib.c -MD -MF .deps/nf_lib.TPlo -fPIC -DPIC -o .libs/nf_lib.o
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -I. -m64 -c -o typeSizes.lo typeSizes.f90
libtool: compile: pgfortran -I. -m64 -c typeSizes.f90 -fpic -o .libs/typeSizes.o
libtool: compile: pgfortran -I. -m64 -c typeSizes.f90 -o typeSizes.o >/dev/null 2>&1
libtool: compile: pgfortran -I. -m64 -c nf_fortv2.f90 -o nf_fortv2.o >/dev/null 2>&1
libtool: compile: pgcc -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -g -O2 -DLONGLONG_IS_LONG -c nf_lib.c -MD -MF .deps/nf_lib.TPlo -o nf_lib.o >/dev/null 2>&1
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o module_netcdf_nc_data.lo module_netcdf_nc_data.F90
/bin/bash …/libtool --tag=FC --mode=compile pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" -DPACKAGE_STRING="netCDF-Fortran\ 4.5.2" -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte -DNF_INT2_T=integer*2 -DNF_INT8_T=integer*8 -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte -DNCSHORT_T=integer*2 -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c -o module_netcdf_nf_data.lo module_netcdf_nf_data.F90
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c module_netcdf_nc_data.F90 -fpic -o .libs/module_netcdf_nc_data.o
NVFORTRAN-F-0004-Corrupt or Old Module file netcdf_nc_data.mod (nf_nc4.f90: 1980)
NVFORTRAN/x86-64 Linux 23.3-0: compilation aborted
make[2]: *** [Makefile:773: nf_nc4.lo] Error 1
make[2]: *** Waiting for unfinished jobs…
make[2]: *** [Makefile:773: nf_fortv2.lo] Error 1
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer2" -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c module_netcdf_nc_data.F90 -o module_netcdf_nc_data.o >/dev/null 2>&1
2” “-DNF_INT8_T=integer8" -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte "-DNCSHORT_T=integer2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c module_netcdf_nf_data.F90 -fpic -o .libs/module_netcdf_nf_data.o
libtool: compile: pgfortran -DPACKAGE_NAME="netCDF-Fortran" -DPACKAGE_TARNAME="netcdf-fortran" -DPACKAGE_VERSION="4.5.2" “-DPACKAGE_STRING="netCDF-Fortran 4.5.2"” -DPACKAGE_BUGREPORT="support-netcdf@unidata.ucar.edu" -DPACKAGE_URL="" -DPACKAGE="netcdf-fortran" -DVERSION="4.5.2" -DNF_RELAX_COORD_BOUND=1 -DENABLE_CDF5=1 -DHAVE_F2008=1 -DHAVE_TS29113_SUPPORT=1 -DTEMP_LARGE="." -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DNF_INT1_T=byte “-DNF_INT2_T=integer2" "-DNF_INT8_T=integer8” -DNF_INT1_IS_C_SIGNED_CHAR=1 -DNF_INT2_IS_C_SHORT=1 -DNF_INT8_IS_C_LONG_LONG=1 -DNF_INT_IS_C_INT=1 -DNF_REAL_IS_C_FLOAT=1 -DNF_DOUBLEPRECISION_IS_C_DOUBLE=1 -DNCBYTE_T=byte “-DNCSHORT_T=integer*2” -DHAVE_LIBM=1 -DHAVE_NETCDF_H=1 -DHAVE_NC_DEF_OPAQUE=1 -DHAVE_NCCREATE=1 -DHAVE_NC_SET_LOG_LEVEL=1 -DHAVE_NC_GET_CHUNK_CACHE_INTS=1 -DUSE_NETCDF4=1 -DLOGGING=1 -DHAVE_SYS_PARAM_H=1 -DHAVE_LOCALE_H=1 -DHAVE_STDIO_H=1 -DHAVE_STDARG_H=1 -DHAVE_ERRNO_H=1 -DHAVE_CTYPE_H=1 -DHAVE_FCNTL_H=1 -DHAVE_MALLOC_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_GETOPT_H=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SYS_RESOURCE_H=1 -DHAVE_DIRENT_H=1 -DSTDC_HEADERS=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_VPRINTF=1 -DHAVE__BOOL=1 -DHAVE_STDBOOL_H=1 -DHAVE_ALLOCA_H=1 -DHAVE_ALLOCA=1 -DHAVE_SSIZE_T=1 -DHAVE_PTRDIFF_T=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=8 -DSIZEOF_FLOAT=4 -DSIZEOF_DOUBLE=8 -DSIZEOF_OFF_T=8 -DSIZEOF_SIZE_T=8 -DSIZEOF_PTRDIFF_T=8 -I. -I/home/essmsd/Documents/Build_WRF/LIBRARIES/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/netcdf/include -I/home/essmsd/Documents/Build_WRF/LIBRARIES/grib2/include -I. -m64 -c module_netcdf_nf_data.F90 -o module_netcdf_nf_data.o >/dev/null 2>&1
make[2]: Leaving directory ‘/home/essmsd/Documents/Build_WRF/netcdf-fortran-4.5.2/fortran’
make[1]: *** [Makefile:602: all] Error 2
make[1]: Leaving directory ‘/home/essmsd/Documents/Build_WRF/netcdf-fortran-4.5.2/fortran’
make: *** [Makefile:540: all-recursive] Error 1
This is one source of the error, but it can also mean that the module was build with an older version of the compilers.
Here, it does appear that you are rebuilding the NetCDF libs and presumably you’ve installed it someplace?
When you build WRF, did you configure it so that it’s using this rebuilt NetCDF installation (via the NETCDF environment variable)? My best guess is that it’s configured to use a different install.
-Mat
Thank you for the reply.
I am doing a clean build of two NetCDFs, one for C and another one for Fortran, and the NETCDF variable was set before installing anything, and the variable does refer to the same install.
I tried executing make as just “make” instead of “make -j 4” and it did push through. However when I checked the installation with Fortran + C + NetCDF + MPI, it fails, but Fortran + C + NetCDF is good. Could it be my installation of MPICH? But, again, MPICH was installed with the same compilers and was installed before any other package.
Update: it seems that there was a previously installed MPI in my workstation, and NetCDF is using it; it was built with GNU. I have removed it from the library, yet the problem still persists. I am also attaching here how I checked the Fortran + C + NetCDF + MPI, which are from here (Compiling WRF).
02_fortran+c+netcdf+mpi_c.c
#ifndef CRAY
# ifdef NOUNDERSCORE
#      define C_TEST c_test
# else
#   ifdef F2CSTYLE
#      define C_TEST c_test__
#   else
#   endif
# endif
#endif
#include <stdio.h>
int C_TEST ( float *xx, int *ii )
 printf("   C function called by Fortran\n" ) ;
 printf("   Values are xx = %5.2f and ii = %d \n", *xx, *ii ) ;
 return(0) ;
02_fortran+c+netcdf+mpi_f.f
        PROGRAM foo
        INCLUDE 'mpif.h'
        !  For netcdf
        INCLUDE 'netcdf.inc'
        INTEGER ncid , status
        !  For Fortran/C
        INTEGER :: ii
        REAL    :: xx
        !  Fortran/C
        ii = 1
        xx = 2
        CALL c_test ( xx , ii )
        !  MPI test
        CALL mpi_init ( status )
        !  netCDF test
        status = nf_open ( 'foo.nc' , 0 , ncid )
        PRINT *,'status = ',status
        !  Close down MPI
        CALL mpi_finalize ( status )
        PRINT *,'SUCCESS test 2 fortran + c + netcdf + mpi'
        END PROGRAM
And the error received is,
   Values are xx =  2.00 and ii = 1
free(): double free detected in tcache 2
I’m not sure what’s wrong. I tired the same code here and it works fine. I’m using the OpenMPI that ships with the NVHPC SDK, which you might try to see if it works around the problem.
One thought is that the binary might be picking up the wrong runtime libraries? Try using “ldd <binary_name>” to see which shared objects it’s picking up and double check these are the correct ones. If it’s wrong, set the environment variable “LD_LIBRARY_PATH” to the directories containing correct SOs.
Good day,
Regarding the Fortran NetCDF, I was able to successfully build it by running “make -j 4” multiple times. Yet, the test still fails. I have tried using the OpenMPI that is with NVHPC SDK, and it did work! Although, it seems to run 16 times (there were 16 success messages). I have run OpenMPI by “/opt/nvidia/hpc_sdk/Linux_x86_64/23.3/comm_libs/mpi/bin/mpif90”, “/opt/nvidia/hpc_sdk/Linux_x86_64/23.3/comm_libs/mpi/bin/mpicc”, and “/opt/nvidia/hpc_sdk/Linux_x86_64/23.3/comm_libs/mpi/bin/mpirun”.
And there’s this message:
The library attempted to open the following supporting CUDA libraries, but each of them failed. CUDA-aware support is disabled.
libcuda.so.1: cannot open shared object file: No such file or directory
libcuda.dylib: cannot open shared object file: No such file or directory
/usr/lib64/libcuda.so.1: cannot open shared object file: No such file or directory
/usr/lib64/libcuda.dylib: cannot open shared object file: No such file or directory
If you are not interested in CUDA-aware support, then run with
–mca mpi_cuda_support 0 to suppress this message. If you are interested
in CUDA-aware support, then try setting LD_LIBRARY_PATH to the location
of libcuda.so.1 to get passed this issue.
15 more processes have sent help message help-mpi-common-cuda.txt / dlopen failed
Set MCA parameter “orte_base_help_aggregate” to 0 to see all help / error messages
I have also tried adding /opt/nvidia/hpc_sdk/Linux_x86_64/23.3/comm_libs/mpi/bin into the PATH variable and /opt/nvidia/hpc_sdk/Linux_x86_64/23.3/comm_libs/mpi/share/man in the MANPATH variable, but they return the same result.
Are these messages expected?
Yes. The messages are indicating that you don’t have the CUDA driver (libcuda.so) installed (or it’s in a non-default locations) and you wont be able to use CUDA Aware MPI. As the message indicates, "If you are not interested in CUDA-aware support, then run with–mca mpi_cuda_support 0 to suppress this message. "
Thank you very much for your assistance!
