Using nvfortran 23.1 I tried to print 3 digits exponent variables with different format specifiactions. For these purposes I used double precision variable and function HUGE and print zero value.
None fmt huge(lv) lv = 0.0_dp
None fmt 1.7976931348623157E+308 0.000000000000000
Use format es27.17E3 1.79769313486231571+308 0.00000000000000000E+00
Use format d27.17 0.17976931348623157+309 0.00000000000000000D+00
Use format G27.17E3 0.17976931348623157E+309 0.0000000000000000
NOT allowed in NVF to use DSw.d
NOT allowed in NVF to use Dw.dEe
The format ES27.17E3 doesn’t print 3 digits in exponential part for double precision.
In case of Single Precision it also works weird.
Use es27.17E3 SPrec 3.40282346638528860E+38 0.00000000000000000E+00
The source of the program is below
program test_format
use iso_fortran_env, only: dp => real64, sp => real32
real(sp), parameter ::sv = 0.0_sp
real(dp), parameter ::lv = 0.0_dp
write(*,'(a,2a27)') "None fmt ", "huge(lv) ", "lv = 0.0_dp "
write(*,*) "None fmt ", huge(lv), lv
write(*,'(a,2es27.17E3)') "Use format es27.17E3 ", huge(lv), lv
write(*,'(a,2d27.17)') "Use format d27.17 ", huge(lv), lv
write(*,'(a,2G27.17E3)') "Use format G27.17E3 ", huge(lv), lv
write(*,'(a)') "NOT allowed in NVF to use DSw.d "
write(*,'(a)') "NOT allowed in NVF to use Dw.dEe "
write(*,'(a,2es27.17E3)') "Use es27.17E3 SPrec ", huge(sv), sv
end program test_format
