When TMPDIR fills up during compilation, NVFORTRAN 26.9 can fail with an internal compiler error. The real cause, a failed write to a temporary file, is not reported:
NVFORTRAN-F-0000-Internal compiler error. Errors in ILM file 52 (.../test_extrap_mpi.f90)
The Fortran front end (fort1) does not seem to check for write errors on its temporary ILM file (and .stb file). It exits with status 0 even when those files are truncated. The back end (fort2) then fails to parse the truncated ILM file and reports an internal compiler error. The source code is fine: the same file compiles once there is space in TMPDIR. A user who hits the full-disk case may take this as a code-generation bug (as we did at first).
Environment
- NVIDIA HPC SDK 26.9
nvfortran 26.9-0 64-bit target on x86-64 Linux -tp cascadelake- Ubuntu 26.04.1 LTS, x86-64
How we hit it
We ran several builds in parallel with the default TMPDIR=/tmp. On this machine, /tmp is a tmpfs with per-user quotas (usrquota). Once the quota was reached:
- one
nvfortran -acc -cuda ...compilation failed with the internal compiler error above; - in the same build, the assembler reported the real cause correctly:
/tmp/nvddNui5i1gOKl32Q.s: Fatal error: can't write 3912 bytes to section .nv_fatbin of /tmp/pgcudafatboi5idCFdHvol.o: 'Disk quota exceeded'
After pointing TMPDIR at a file system with free space, the same source compiles without errors.
MRE
The reproducer below instead uses a per-process file-size limit (ulimit -f), which makes write(2) on the temporary files fail with EFBIG, the same way it fails with ENOSPC/EDQUOT on a full disk. SIGXFSZ is ignored so that the compiler sees the failed write instead of being killed.
Save as hello.f90:
program hello
implicit none
real :: a(100)
integer :: i
a = [(real(i), i=1,100)]
print *, sum(a)
end program hello
Run:
nvfortran -c hello.f90 # control: compiles fine
bash -c "trap '' XFSZ; ulimit -f 4; nvfortran -c hello.f90" # writes beyond 4 KiB fail
The compilation fails with exit status 2. About 50 lines like
ILM file line 45: expecting bit ptrsafe
instead got:
are followed by
NVFORTRAN-F-0000-Internal compiler error. Errors in ILM file 53 (hello.f90)
Other limits produce other misleading messages, also without an I/O error:
With
ulimit -f 2, the only hint is a non-fatal message from the front end:lower_ilm_finish - fseek on lower_ilm_file: File too large NVFORTRAN-F-0000-Internal compiler error. Errors in ILM file 21 (hello.f90) -
With
ulimit -f 8:IILM file version error Expecting DIRECTIVES version 1/69 got version 0/0
Expected result and controls
We expect a diagnostic that names the I/O failure and the temporary file, as NVFORTRAN already does for its “state file” in the same situation. With an internal procedure, for example in internal.f90:
program internal
implicit none
call s()
contains
subroutine s()
print *, 'hello'
end subroutine s
end program internal
the same command
bash -c "trap '' XFSZ; ulimit -f 4; nvfortran -c internal.f90"
reports the error correctly:
NVFORTRAN-F-0010-File write error occurred (state file) (internal.f90)
NVFORTRAN/x86-64 Linux 26.9-0: compilation aborted
So it seems that only the writes to the ILM (and .stb) files go unchecked.
Thanks in advance for looking into this!
Pedro
AI Disclaimer: Post drafted with the help of Claude Code.
