Nvfortran trim not trim newline
The nvfortran trim function not trim newline, but the Gfortran and ifort dose.
It makes me have lot works to do. when I migrating a old fortran program to cuda fortran.
Is this behavior a bug OR expect?
for example:
    write(*,*) 'should be 9 but get 10:',len(trim('nvfortran\n'))
    write(*,*) 'should be 9 and get 9:',len(trim('nvfortran '))
Hi jubilee2,
“TRIM” only removes trailing blank spaces, I don’t believe it’s expected to remove special characters like newlines.
In running your example, both gfortran an ifort don’t treat “\n” as a newline character, but even when using a string with a newline appended, they still don’t remove it.
Is the string you’re using coming from C? Can you provide an example which illustrates the issue in your full program?
Example:
$ cat test.f90
    write(*,*) 'should be 9 but get 10:',len(trim('nvfortran\n')), trim('nvfortran\n')
    write(*,*) 'should be 9 and get 9:',len(trim('nvfortran ')), trim('nvfortran ')
    end
$ gfortran test.f90; a.out
 should be 9 but get 10:          11 nvfortran\n
 should be 9 and get 9:           9 nvfortran
$ ifort test.f90; a.out
$ nvfortran test.f90; a.out
 should be 9 but get 10:           10 nvfortran
$ cat test2.f90
    character(80) :: str1 = "nvfortran"//char(10)
    character(80) :: str2 = "nvfortran "
    write(*,*) 'should be 9 but get 10:',len(trim(str1)), trim(str1)
    write(*,*) 'should be 9 and get 9:',len(trim(str2)), trim(str2)
    end
$ gfortran test2.f90; a.out
$ ifort test2.f90; a.out
$ nvfortran test2.f90; a.out
I should mention, if you want nvfortran to match the behavior of gfortran/ifort in the first example, i.e. treat “\n” as two characters instead of a newline, add the flag “-Mbackslash”.
$ nvfortran -Mbackslash test.f90; a.out
Thanks for quick responding. Yes I test again. THEN realize those newline char comes from read() function.
I first think the issue related with “trim” because the error messages say that line have error during passing the string into a dynamic library (mylib.so) function.
thanks for help.
call someting_c_fuction(filename//C_NULL_CHAR)
by the way if I find newline issue in read function do you want me replay in this chain or open other post?
HI every one,
now I realized it is CR LF things. The Nvfortran read function only remove “LF” char but keep “CR” char
program test
  character(len=20) :: readLine
  open(11,file='txt.txt')
  read(11,*) readLine
  close(11)
  print *, len(trim(readLine))
end
txt.txt (under CR LX mode)(windows mode)
hello
result
$ nvfortran test.f90 && ./a.out
            6
$ gfortran test.f90 && ./a.out
           5
Two solutions.
  1. Run the “dos2unix” utility on your txt file to convert it to use UNIX formatting, or
  2. Set the environment variable FORTRANOPT set to “crlf” to have our runtime use Windows style formating.
Example:
% nvfortran test.f90; a.out
            6 hello
% setenv FORTRANOPT crlf
% nvfortran test.f90 ; a.out
            5 hello
Hope this helps,
Mat
