The following valid Fortran 2003 code is not processed by the nvfortran compiler (nvfortran 22.1-0 64-bit target on x86-64 Linux -tp skylake-avx512).
module dftbp_geoopt_package
implicit none
private
type, abstract :: TOptimizerInput
end type TOptimizerInput
type, extends(TOptimizerInput) :: TFireInput
end type TFireInput
type, extends(TOptimizerInput) :: TLbfgsInput
end type TLbfgsInput
type, extends(TOptimizerInput) :: TRationalFuncInput
end type TRationalFuncInput
contains
subroutine createOptimizer(input)
class(TOptimizerInput), intent(inout) :: input
select type (input)
type is (TLbfgsInput)
block
print *, "TLbfgsInput"
end block
return
type is (TRationalFuncInput)
block
print *, "TRationalFuncInput"
end block
return
type is (TFireInput)
block
print *, "TFireInput"
end block
return
end select
end subroutine createOptimizer
end module dftbp_geoopt_package
Compiling the code results in
nvfortran -c ~/package.f90
NVFORTRAN-S-0044-Multiple declaration for symbol is (/home/aradi/package.f90: 38)
NVFORTRAN-S-0117-Statement not allowed within a derived type definition (/home/aradi/package.f90: 38)
0 inform, 0 warnings, 2 severes, 0 fatal for createoptimizer
Interestingly, if the block
statements are removed, the code is at least compiled…
