NVFP4 LoRA training on Nemotron-3-Super-120B recipe
Hey guys, I was playing around with larger models on the DGX Spark with NVFP4 quantization, and wanted to share a result from it, a stack that works for LoRA fine-tuning and serving the Nemotron-3-Super-120B MoE model on a single spark.
Repo: GitHub - NvMayMay/nvfp4-lora-spark: LoRA fine-tuning and serving for NVIDIA Nemotron-3 NVFP4 MoE models on a single NVIDIA DGX Spark (GB10, 128 GB UMA) · GitHub
The main problem is that NVIDIA’s Nemotron-3 NVFP4 checkpoints are efficient to run, but they are not directly compatible with standard LoRA tooling. The weights are stored as packed NVFP4 values with FP8 block scales and a per-tensor FP32 scale, and the model also mixes in FP8 Mamba/shared-expert layers. Off-the-shelf PEFT paths do not really handle that cleanly.
So this project takes a different route:
  • keep the NVFP4 base weights frozen in their compressed form
  • dequantize on the fly to bf16 inside a custom autograd path
  • train only the LoRA adapters
  • merge the adapter back into the NVFP4 base
  • serve the merged checkpoint with vLLM on DGX Spark
The target hardware is a single DGX Spark (GB10, 128 GB unified memory, CUDA 13).
What the repo includes
  • NVFP4-aware LoRA layers and loader code
  • training scripts for Nano-30B and Super-120B
  • merge + re-quantization pipeline
  • validation scripts for merge correctness
  • serving recipes for vLLM
  • reproducibility notes, troubleshooting, and benchmark artifacts
Headline results
Training on a single DGX Spark
Model Base format LoRA targets Peak memory Step time Final loss
Nemotron-3 Super 120B NVFP4 up_proj, down_proj 93.2 GB 135.6 s 0.81
Nemotron-3 Nano 30B NVFP4 up_proj, down_proj 36.1 GB 43.8 s 1.00
Nemotron-3 Nano 30B BF16 up_proj, down_proj 67.5 GB sampled 4.2 s 0.98
A useful result here is that the Nano NVFP4 vs BF16 ablation showed very similar training loss, while NVFP4 used much less memory. The tradeoff is speed: NVFP4 training is slower, but it makes models fit that otherwise would not fit on this box at all.
Serving results
Serving path Throughput on DGX Spark
Super-120B base, vLLM CUTLASS ~11-14 tok/s
Super-120B merged FT, vLLM CUTLASS ~12-14 tok/s
Super-120B merged FT, concurrency 3 up to ~40 tok/s aggregate
Nano-30B FT, concurrency 8 up to ~339 tok/s aggregate
One of the practical conclusions was that for Super-120B, the most reliable path was merge-then-serve rather than dynamic LoRA attachment at request time.
Why this was interesting
The part I found most interesting was that this was less a “fine-tuning script” problem and more a systems problem:
  • quantized storage format compatibility
  • on-the-fly dequantization without keeping a persistent bf16 shadow
  • unified-memory behavior on GB10
  • kernel/toolchain quirks on Blackwell-class local hardware
  • getting a serving path that preserves FT behavior without giving up native NVFP4 speed
If anyone is experimenting with NVFP4 on the DGX Spark, or local fine-tuning of large MoE models, it would be great to connect as I’m still finding my feet with this setup!
What context length did you train with? Very low context fine tuning is not very useful unless being used to demonstrate fine tuning to someone or doing a style tune.
I successfully got up to a context length of 4096 with a batch size of 2 on the Super and Nano models, but I think the Nano could be pushed a bit further. I will have a look and see how much I can push the context window out by, as you’re right that it is a limiting factor
So I did some more playing around and the base version got up to a context length of 24576 at r=8 and was stable but left only 2.6GB available. Ran some experiments and created some efficiencies so now it is possible to use a cached pre-fix and trainable suffix to add in some more context. Reached 65k context with 2k adapter size, or 262k context with 1k adapter size. I will continue to push this and find more ways to get the trainable params up.
