Well … the USB is a UART and I think they are connected? Anyways, The can’t access interface 0 error seems more of a permissions/resource availability error. There is plenty of power on the camera available there is no issue there. If it was a power issue, the issue would be present regardless of the state of nvgetty.
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Video, Driver=uvcvideo, 5000M
|__ Port 1: Dev 2, If 1, Class=Video, Driver=uvcvideo, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/5p, 480M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/2p, 480M
|__ Port 2: Dev 6, If 0, Class=Human Interface Device, Driver=, 12M
|__ Port 3: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 4, If 0, Class=Vendor Specific Class, Driver=rtl8821cu, 480M
|__ Port 2: Dev 5, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 2: Dev 5, If 1, Class=Wireless, Driver=btusb, 12M
dmesg
[74705.712543] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74706.559161] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74707.405700] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74708.252525] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74709.099113] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74718.609504] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74721.321696] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74730.832967] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74731.679560] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74736.767061] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74737.613796] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74738.460563] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74739.307045] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74740.153840] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74741.000652] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74741.847251] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74742.693977] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74745.915536] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74746.762273] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74756.273300] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74757.119972] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74762.887852] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74763.734679] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74764.581282] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74765.428019] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74774.939404] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74775.785958] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74776.632750] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74777.479481] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74786.989955] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74796.488315] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74805.982609] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74815.476771] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74816.368964] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74825.865186] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74835.359090] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74837.841316] soctherm: OC ALARM 0x00000001
[74844.853054] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74845.745586] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74855.240148] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74864.734051] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74865.623345] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74866.469974] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74867.316810] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74876.827257] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74877.673931] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74878.520709] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74879.367329] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74880.214082] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74881.060707] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74890.570973] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74900.069561] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74909.563056] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74910.433199] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74911.279856] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74912.126301] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74912.973177] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74913.819781] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74914.666428] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74924.176514] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74925.023049] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74934.532372] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74944.031552] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[74967.837723] soctherm: OC ALARM 0x00000001
[74982.063868] soctherm: OC ALARM 0x00000001
[75004.656277] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75005.502928] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75006.349720] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75015.859504] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75025.359115] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75034.853901] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75035.722409] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75045.226599] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75046.073326] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75046.920025] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75047.766693] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75057.276910] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75065.561994] soctherm: OC ALARM 0x00000001
[75066.776559] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75076.270633] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75085.765050] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75086.652849] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75096.153498] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75097.833496] soctherm: OC ALARM 0x00000001
[75103.061028] soctherm: OC ALARM 0x00000001
[75105.648446] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75115.143203] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75115.988757] soctherm: OC ALARM 0x00000001
[75116.036202] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75125.531095] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75135.026277] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75135.900648] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75136.747427] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75137.594015] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75138.440684] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75147.951819] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75148.798303] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75157.949267] soctherm: OC ALARM 0x00000001
[75158.307704] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75159.154411] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75160.001328] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75160.847989] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75161.694655] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75162.541357] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75163.388546] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75164.235417] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75165.082134] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75165.928816] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75166.775334] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75167.621966] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75168.468742] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75169.315482] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75170.162381] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75179.672249] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75180.518918] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75181.365802] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75190.876329] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75191.723071] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75201.234573] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75202.081491] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75202.928038] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75203.774810] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75213.090772] soctherm: OC ALARM 0x00000001
[75213.285511] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75222.783817] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75227.829637] soctherm: OC ALARM 0x00000001
[75232.277856] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75233.147758] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75233.994361] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75243.504817] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75244.351485] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75253.862523] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75263.360337] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75272.853500] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75280.340970] soctherm: OC ALARM 0x00000001
[75282.347561] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75283.240269] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75292.734224] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75302.228007] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75311.722183] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75312.614958] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75322.108878] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75331.602853] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75332.491981] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75333.338448] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75342.848512] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75352.348814] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75357.827065] soctherm: OC ALARM 0x00000001
[75361.842607] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75362.710409] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75363.557170] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75364.403796] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75373.914444] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75383.413366] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75392.907352] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75402.401422] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75403.294991] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75412.789290] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75422.284424] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75423.170218] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75424.016723] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75433.527345] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75443.027614] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75465.892547] soctherm: OC ALARM 0x00000001
[75487.825075] soctherm: OC ALARM 0x00000001
[75528.095570] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75537.606456] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75538.453198] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75547.964293] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75557.462162] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75566.956568] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75567.831396] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75568.677963] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75578.188673] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75587.687663] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75597.182413] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75598.051271] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75598.897994] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75599.744688] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75608.011357] soctherm: OC ALARM 0x00000001
[75609.255531] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75611.458738] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75612.305337] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75615.526792] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75616.373321] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75625.884423] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75626.731045] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75636.242036] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75637.088915] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75646.600274] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75647.447144] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75648.294035] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75649.140960] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75649.987758] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75659.499452] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75660.346207] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75669.857675] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75679.355913] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75688.850221] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75689.729161] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75699.238641] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75708.733356] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75718.228127] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75719.108134] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75719.954569] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75720.801576] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75730.313121] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75731.160015] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75732.006753] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75732.853481] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75733.700351] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75734.546977] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75737.821334] soctherm: OC ALARM 0x00000001
[75744.058737] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75744.905700] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75745.752494] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75746.599369] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75748.802450] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75749.649434] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75750.496061] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75751.342663] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75754.055297] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75754.902173] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75766.279603] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75775.792411] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75785.286333] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75798.265473] soctherm: OC ALARM 0x00000001
[75799.385319] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75800.232346] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75801.079057] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75814.493341] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75815.339910] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75823.654350] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75824.501286] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75846.402309] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75847.249575] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75848.096185] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75862.529504] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75867.817502] soctherm: OC ALARM 0x00000001
[75872.039994] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75872.886876] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75882.397441] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75883.244284] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75884.090911] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75893.601012] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75894.447697] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75895.294511] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75896.141220] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75905.651448] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75906.498110] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75907.344802] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75908.191476] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75909.038139] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75909.884906] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75910.731843] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75911.578540] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75912.424952] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75913.271856] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75914.118564] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75914.965313] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75915.811949] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75916.658838] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75917.505372] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75918.352244] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75919.198867] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75920.045614] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75920.892156] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75921.738998] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75922.585708] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75923.432220] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75932.942981] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75933.789586] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75934.636479] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75935.483342] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75936.329992] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75937.176887] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75938.023460] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75938.870334] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75939.717239] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75940.564014] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75949.750352] soctherm: OC ALARM 0x00000001
[75950.075074] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75959.574236] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75965.594016] soctherm: OC ALARM 0x00000001
[75969.069017] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75969.938782] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75970.785712] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75980.295192] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75981.141821] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75981.988777] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75982.835478] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75992.345980] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75993.192491] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75994.039306] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75994.885828] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75995.732780] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75996.579309] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75997.426132] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[75997.813103] soctherm: OC ALARM 0x00000001
[75998.272875] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76007.181123] soctherm: OC ALARM 0x00000001
[76007.783877] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76008.630777] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76009.477252] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76010.323995] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76011.141248] soctherm: OC ALARM 0x00000001
[76011.170785] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76012.017547] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76012.864435] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76013.710930] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76023.221016] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76024.067905] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76033.578177] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76043.076803] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76052.570970] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76062.064339] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76062.957319] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76072.451385] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76081.945213] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76082.826878] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76083.673581] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76084.520183] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76085.367480] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76086.214851] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76087.061812] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76087.908550] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76088.755574] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76089.602584] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76090.449633] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76091.296649] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76092.143723] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76092.990486] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76093.837524] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76094.684906] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76095.531861] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76096.379131] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76097.226123] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76098.072873] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76098.919894] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76099.766798] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76100.614081] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76101.461433] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76102.308214] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76103.155531] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76104.002713] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76104.849794] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76105.696639] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76106.543936] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76107.390990] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76108.237805] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76109.084828] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76109.931890] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76110.779172] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76111.626041] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76112.472932] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76113.319605] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76114.166406] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76115.013232] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76115.860162] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76116.707075] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76120.947854] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76123.151125] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76123.998373] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76124.845262] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76125.692195] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76127.809590] soctherm: OC ALARM 0x00000001
[76135.204287] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76136.051526] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76136.898490] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76145.213881] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76146.060921] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76146.907917] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76147.754939] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76148.601861] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76149.448818] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76150.295626] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76151.142357] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76151.989108] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76158.776988] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76159.623686] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76165.901993] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76166.748815] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76167.595458] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76169.798769] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76170.645756] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76171.492636] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76172.339528] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76173.186307] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76174.032928] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76174.879693] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76175.726738] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76176.573289] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76186.085362] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76186.932448] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76189.969070] soctherm: OC ALARM 0x00000001
[76193.209931] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76194.056974] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76194.904166] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76195.750977] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76201.858119] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76202.705032] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76203.552083] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76204.398757] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76205.245734] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76206.092792] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76206.939853] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76207.786706] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76208.633516] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76213.892538] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76223.402457] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76224.249099] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76233.759723] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76243.260887] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76257.816840] soctherm: OC ALARM 0x00000001
[76322.102340] soctherm: OC ALARM 0x00000001
[76326.062590] soctherm: OC ALARM 0x00000001
[76336.958000] soctherm: OC ALARM 0x00000001
[76347.689303] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76348.536108] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76358.048079] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76358.894942] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76359.741781] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76361.944734] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76369.750617] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76370.597467] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76371.444219] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76372.291189] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76373.137998] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76373.984583] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76376.697166] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76377.544311] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76387.056180] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76387.903074] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76397.414209] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76398.260995] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76400.972933] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76410.483696] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76419.984999] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76429.480108] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76430.350593] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76434.081728] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76434.928789] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76435.775652] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76436.622626] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76437.469404] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76438.316357] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76442.556592] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76452.068195] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76461.567919] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76471.063378] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76471.933537] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76481.444581] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76482.291267] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76491.802902] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76501.302952] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76507.982035] soctherm: OC ALARM 0x00000001
[76510.798461] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76511.668264] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76521.179074] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76522.025837] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76522.872570] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76532.383006] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76541.883965] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76637.798876] soctherm: OC ALARM 0x00000001
[76767.796071] soctherm: OC ALARM 0x00000001
[76794.024159] soctherm: OC ALARM 0x00000001
[76824.584248] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76825.431080] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76826.277869] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76827.124654] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76827.971594] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76828.818597] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76838.329533] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76839.176337] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76848.688274] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76849.534924] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76850.381546] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76859.893204] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76860.739909] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76861.586730] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76871.097375] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76880.597219] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76882.586394] soctherm: OC ALARM 0x00000001
[76890.092850] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76897.793947] soctherm: OC ALARM 0x00000001
[76899.587592] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76900.479521] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76901.326436] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76902.173145] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76906.151628] soctherm: OC ALARM 0x00000001
[76911.685206] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76912.532221] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76913.378944] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76922.890737] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76923.737602] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76933.249477] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76942.748843] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76952.243375] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76953.111762] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76953.958658] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76963.469644] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76964.316588] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76965.163159] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76966.010171] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76966.856846] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76967.703610] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76968.550052] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76969.397040] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76970.243926] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76971.090789] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76971.937569] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76972.784644] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76982.295362] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[76991.794996] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77001.289045] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77004.379475] soctherm: OC ALARM 0x00000001
[77010.783655] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77011.677960] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77021.172268] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77025.430573] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77026.277239] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77027.124101] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77027.793434] soctherm: OC ALARM 0x00000001
[77033.910612] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77035.019096] soctherm: OC ALARM 0x00000001
[77043.422418] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77044.269101] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77053.779936] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77063.278682] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77072.772746] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77082.267220] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77083.160729] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77092.657012] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77102.151647] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77103.031603] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77112.540746] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77122.035159] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77131.525734] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77132.393556] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77141.887192] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77142.780399] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77152.274847] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77157.793589] soctherm: OC ALARM 0x00000001
[77161.768950] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77162.655439] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77172.156168] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77287.785732] soctherm: OC ALARM 0x00000001
[77388.567668] soctherm: OC ALARM 0x00000001
[77407.963090] soctherm: OC ALARM 0x00000001
[77484.369397] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77493.879936] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77503.377252] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77505.641048] soctherm: OC ALARM 0x00000001
[77512.870483] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77513.749244] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77514.595903] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77524.106244] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77533.604783] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77537.780340] soctherm: OC ALARM 0x00000001
[77543.098125] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77543.967826] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77553.478344] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77562.977219] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77572.471396] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77581.965532] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77582.852502] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77592.354074] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77625.754108] soctherm: OC ALARM 0x00000001
[77689.989522] soctherm: OC ALARM 0x00000001
[77765.001551] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77765.848688] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77766.695737] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77767.542648] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77768.389648] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77769.236606] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77770.083582] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77770.930448] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77771.777382] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77772.624483] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77773.471621] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77774.318858] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77775.165604] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77776.012675] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77776.859833] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77777.707220] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77778.554267] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77779.401547] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77780.248633] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77781.095796] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77781.943140] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77782.790130] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77783.637420] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77784.484559] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77785.331438] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77786.178578] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77787.025602] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77787.872645] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77788.719735] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77789.566627] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77790.413698] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77791.260849] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77792.108040] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77792.954768] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77793.801981] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77794.648880] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77795.496044] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77796.343082] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77797.190155] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77797.774955] soctherm: OC ALARM 0x00000001
[77798.036895] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77798.883661] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77799.730377] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77800.577204] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77801.423876] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77802.270551] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77803.117271] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77803.964313] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77804.811336] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77805.658425] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77806.505136] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77807.352063] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77808.199025] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77809.045695] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77809.892221] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77810.739053] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77811.585798] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77812.432458] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77813.279361] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77814.126508] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77823.637650] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77833.135738] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77839.429374] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77842.141921] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77851.653965] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77860.478939] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77861.325771] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77862.172887] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77863.019591] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77863.866400] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77873.377521] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77874.224347] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77875.071393] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77875.918092] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77876.764748] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77880.001187] soctherm: OC ALARM 0x00000001
[77881.005527] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77884.736540] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77885.583561] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77886.430701] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77887.277425] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77888.124567] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77888.971324] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77889.818022] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77899.330045] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77900.176540] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77901.023451] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77910.535366] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77920.032735] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77927.772107] soctherm: OC ALARM 0x00000001
[77929.527486] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77930.409803] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77939.916312] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77949.410872] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77950.278670] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77959.789641] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77969.290984] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77978.785691] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77988.280060] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77989.172626] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[77991.426925] soctherm: OC ALARM 0x00000001
[77998.667537] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78008.162595] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78009.041401] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78018.550567] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78028.045070] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78037.536577] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78038.403973] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78047.898539] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78048.784904] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78058.286075] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78187.766672] soctherm: OC ALARM 0x00000001
[78307.944152] soctherm: OC ALARM 0x00000001
[78363.991121] soctherm: OC ALARM 0x00000001
[78371.902918] soctherm: OC ALARM 0x00000001
[78437.761828] soctherm: OC ALARM 0x00000001
[78500.855202] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78501.702300] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78502.549060] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78503.396103] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78504.243039] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78505.090153] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78505.937061] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78506.784180] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78507.630923] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78508.477853] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78509.324742] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78510.171511] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78511.018267] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78511.865385] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78516.615529] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78517.462029] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78518.309013] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78519.155873] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78520.002802] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78520.849986] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78524.072065] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78524.919043] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78525.766044] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78526.613014] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78527.459948] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78531.701083] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78532.548079] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78536.279451] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78537.126292] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78537.279411] soctherm: OC ALARM 0x00000001
[78537.973255] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78538.820064] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78539.666835] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78540.513631] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78541.360812] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78550.873001] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78551.719623] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78552.566371] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78553.413491] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78554.260292] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78563.770947] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78564.617629] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78565.464528] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78566.311163] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78567.158396] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78567.758280] soctherm: OC ALARM 0x00000001
[78576.669635] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78577.516094] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78578.363306] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78587.874340] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78595.171496] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78596.018569] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78596.865636] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78597.712434] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78598.559403] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78599.406325] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78600.253236] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78601.100054] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78601.946930] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78602.793942] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78603.641046] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78604.488250] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78604.985890] soctherm: OC ALARM 0x00000001
[78605.335153] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78606.182020] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78607.028956] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78607.875811] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78608.722393] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78609.569612] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78610.416391] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78611.263212] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78620.597418] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78623.310069] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78624.156975] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78625.003691] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78625.850644] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78626.697433] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78627.544430] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78628.391511] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78629.238083] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78630.085032] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78630.931666] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78631.778689] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78632.625523] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78633.471994] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78634.319055] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78635.165756] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78636.012643] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78636.859307] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78637.706320] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78638.553308] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78639.400118] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78640.247185] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78641.094205] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78643.297536] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78644.144533] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78644.991186] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78645.838315] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78646.205055] soctherm: OC ALARM 0x00000001
[78646.685006] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78647.531976] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78648.378792] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78649.225466] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78650.072388] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78650.919214] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78651.765934] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78652.612911] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78653.459972] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78654.307013] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78655.154017] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78656.001027] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78656.847699] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78657.694561] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78658.541387] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78659.388186] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78660.235227] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78675.007049] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78675.853955] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78676.700870] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78677.547866] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78679.751281] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78680.598196] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78681.444754] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78685.685274] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78686.532235] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78696.043862] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78696.890760] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78697.737516] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78697.766050] soctherm: OC ALARM 0x00000001
[78698.584292] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78699.431108] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78700.277821] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78701.124591] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78701.971511] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78702.818317] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78719.797670] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78720.644511] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78721.491409] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78722.338193] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78723.185141] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78724.031804] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78724.878413] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78725.725439] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78726.572183] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78727.418766] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78736.930236] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78737.777609] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78747.289018] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78748.136235] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78748.983029] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78749.829652] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78750.676978] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78751.523757] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78752.370367] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78753.217199] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78754.063980] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78754.910736] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78755.757513] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78756.604215] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78757.451013] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78758.297952] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78767.809087] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78768.655885] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78770.858908] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78771.706052] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78781.216935] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78790.715071] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78796.327593] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78802.605896] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78803.452957] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78804.299907] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78805.147124] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78805.993896] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78812.272483] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78813.119611] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78813.966596] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78814.813606] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78815.660558] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78816.507619] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78817.354616] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78820.067314] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78820.914513] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78821.761306] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78822.608434] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78823.455291] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78824.302287] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78825.149179] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78825.996185] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78826.843342] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78827.690309] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78827.753917] soctherm: OC ALARM 0x00000001
[78828.537552] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78829.384790] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78830.231659] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78831.078746] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78831.925598] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78832.772583] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78833.619535] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78834.466342] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78835.313453] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78836.160313] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78837.007158] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78837.854184] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78838.701138] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78839.548034] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78843.279676] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78844.126846] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78844.973679] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78845.820619] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78846.667187] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78847.513986] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78848.360724] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78849.207774] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78850.054559] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78850.901896] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78851.748797] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78852.595671] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78853.442553] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78854.289547] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78855.136452] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78864.648747] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78865.495470] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78866.342780] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78867.189695] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78868.036457] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78868.883526] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78869.730613] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78878.555211] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78879.402147] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78880.249092] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78881.095830] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78881.942634] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78882.789540] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78883.636262] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78884.483150] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78885.329754] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78886.176570] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78887.023667] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78896.535078] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78897.381599] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78898.228372] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78902.468867] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78903.315680] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78904.162816] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78912.478620] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78913.325645] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78917.566344] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78918.413420] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78927.925133] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78931.656345] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78932.503174] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78933.350039] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78934.196785] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78935.043759] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78935.890798] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78941.659083] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78942.506099] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78943.352710] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78951.735203] soctherm: OC ALARM 0x00000001
[78952.863046] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78953.709839] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78957.750201] soctherm: OC ALARM 0x00000001
[78963.220495] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78972.720814] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78982.216028] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78991.711316] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[78992.603453] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79002.102304] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79011.597091] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79016.272871] soctherm: OC ALARM 0x00000001
[79021.091732] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79021.986059] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79031.480616] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79040.974508] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79041.856910] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79042.703674] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79052.214963] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79053.061736] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79053.908684] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79054.755608] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79064.267561] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79065.114475] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79065.961659] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79066.808241] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79076.319576] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79077.166142] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79079.369242] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79080.215996] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79087.749908] soctherm: OC ALARM 0x00000001
[79089.727172] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79090.573991] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79100.085516] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79109.582062] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79110.442946] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79111.289802] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79120.801177] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79130.301971] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79139.797525] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79149.292547] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79150.182668] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79151.029487] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79151.876606] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79152.723604] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79162.234705] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79173.612539] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79174.459220] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79175.306057] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79176.152918] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79176.999744] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79177.846817] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79185.142619] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79194.654331] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79200.422747] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79201.269546] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79207.915550] soctherm: OC ALARM 0x00000001
[79210.780600] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79220.280233] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79229.775049] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79230.645265] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79231.492141] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79241.004270] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79246.152171] soctherm: OC ALARM 0x00000001
[79250.502123] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79259.996768] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79260.867142] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79270.378361] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79279.877828] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79289.372443] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79290.249184] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79291.095937] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79300.607731] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79301.454436] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79302.300944] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79311.812586] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79321.309768] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79327.973584] soctherm: OC ALARM 0x00000001
[79330.803462] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79331.691268] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79332.538400] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79333.384992] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79337.745130] soctherm: OC ALARM 0x00000001
[79342.719446] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79343.566581] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79344.413273] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79345.260018] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79354.774962] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79364.269863] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79373.764282] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79374.651967] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79384.152750] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
[79393.647637] serial-tegra 70006040.serial: RxData DMA copy to tty layer failed
