Nvgpu err[2200] +err[164]
Hi, all.
jetson nano B01
my carried board.
R32 (release), REVISION: 4.2, GCID: 20074772, BOARD: t210ref, EABI: aarch64, DATE: Thu
when my device run 6~8h, It will report err "
[24767.744507] nvgpu: 57000000.gpu gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 496 to be removed from TSG 9 has NEXT set!
[24767.757030] nvgpu: 57000000.gpu gk20a_tsg_unbind_channel:164 [ERR] Channel 496 unbind failed, tearing down TSG 9
4.057737] l4tbr0: port 2(usb0) entered disabled state
[ 4.058333] device usb0 entered promiscuous mode
[ 4.070046] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.214892] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[ 4.226317] tegra_cec 70015000.tegra_cec: Sent res: -62.
[ 4.235777] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 4.662400] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.665071] eth0: 0xffffff800a4ba000, 48:b0:2d:55:a3:c1, IRQ 405
[ 4.756293] zram: Added device: zram0
[ 4.760269] zram: Added device: zram1
[ 4.763164] zram: Added device: zram2
[ 4.766182] zram: Added device: zram3
[ 4.812264] zram0: detected capacity change from 0 to 518557696
[ 4.838808] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.874614] Adding 506400k swap on /dev/zram0. Priority:5 extents:1 across:506400k SS
[ 4.898301] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 4.930719] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 4.933704] zram1: detected capacity change from 0 to 518557696
[ 4.962348] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 4.962790] r8152 1-2.1:1.0 eth1: carrier on
[ 4.970402] Adding 506400k swap on /dev/zram1. Priority:5 extents:1 across:506400k SS
[ 4.982395] zram2: detected capacity change from 0 to 518557696
[ 5.014375] Adding 506400k swap on /dev/zram2. Priority:5 extents:1 across:506400k SS
[ 5.035668] zram3: detected capacity change from 0 to 518557696
[ 5.053662] Adding 506400k swap on /dev/zram3. Priority:5 extents:1 across:506400k SS
[ 5.292150] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.292156] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.444219] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 5.447485] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 5.449136] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 5.452914] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 5.452918] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[ 5.452921] tegradc tegradc.1: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[ 5.453683] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 5.455608] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 5.456993] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 5.458898] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 5.458902] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[ 5.458905] tegradc tegradc.1: dp: NV_DPCD_MAX_LANE_COUNT read failed
[ 5.458908] tegradc tegradc.1: dp: Invalid link rate (0) or lane count (0)
[ 5.541745] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 5.550022] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 5.551983] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 5.553509] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 5.553514] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[ 5.553516] tegradc tegradc.1: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[ 5.554187] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 5.555898] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 5.557387] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 5.559313] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 5.559317] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[ 5.559320] tegradc tegradc.1: dp: NV_DPCD_MAX_LANE_COUNT read failed
[ 5.559323] tegradc tegradc.1: dp: Invalid link rate (0) or lane count (0)
[ 5.615313] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.638138] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620
[ 5.638145] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.638149] usb 2-1: Product: USB3.2 Hub
[ 5.638153] usb 2-1: Manufacturer: GenesysLogic
[ 5.639254] hub 2-1:1.0: USB hub found
[ 5.639594] hub 2-1:1.0: 4 ports detected
[ 5.669549] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 5.671590] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 5.673112] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 5.675217] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 5.675221] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[ 5.675224] tegradc tegradc.1: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[ 5.676252] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 5.677720] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 5.679723] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 5.681173] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 5.681177] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[ 5.681180] tegradc tegradc.1: dp: NV_DPCD_MAX_LANE_COUNT read failed
[ 5.681183] tegradc tegradc.1: dp: Invalid link rate (0) or lane count (0)
[ 5.739169] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 5.740646] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 5.742117] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 5.746686] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 5.746690] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[ 5.746692] tegradc tegradc.1: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[ 5.747327] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 5.748788] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 5.751365] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 5.753985] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 5.753989] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[ 5.753992] tegradc tegradc.1: dp: NV_DPCD_MAX_LANE_COUNT read failed
[ 5.753995] tegradc tegradc.1: dp: Invalid link rate (0) or lane count (0)
[ 5.927350] usb 2-1.3: new SuperSpeed USB device number 3 using tegra-xusb
[ 5.949958] usb 2-1.3: New USB device found, idVendor=05e3, idProduct=0749
[ 5.949964] usb 2-1.3: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 5.949969] usb 2-1.3: Product: USB3.0 Card Reader
[ 5.949973] usb 2-1.3: Manufacturer: Generic
[ 5.949976] usb 2-1.3: SerialNumber: 000000001532
[ 5.951138] usb-storage 2-1.3:1.0: USB Mass Storage device detected
[ 5.953777] scsi host0: usb-storage 2-1.3:1.0
[ 6.066243] SetAudioSampleRate = [130]
[ 6.968157] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 1532 PQ: 0 ANSI: 6
[ 6.980187] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 7.517766] SetAudioSampleRate = [130]
[ 7.518469] dvrs_hw StartSys
[ 9.381002] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 9.383655] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 9.385166] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 9.386785] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 9.386789] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[ 9.386792] tegradc tegradc.1: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[ 9.387475] tegradc tegradc.1: dp: aux read retry (0x10000100) – 2
[ 9.388976] tegradc tegradc.1: dp: aux read retry (0x10000100) – 1
[ 9.390514] tegradc tegradc.1: dp: aux read retry (0x10000100) – 0
[ 9.392006] tegradc tegradc.1: dp: aux read got error (0x10000100)
[ 9.392011] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[ 9.392014] tegradc tegradc.1: dp: NV_DPCD_MAX_LANE_COUNT read failed
[ 9.392017] tegradc tegradc.1: dp: Invalid link rate (0) or lane count (0)
[ 13.535177] [MV]No Audio Buffer to wirte
[ 13.543512] [MV]No Audio Buffer to wirte
[ 13.676856] [MV]No Audio Buffer to wirte
[ 13.685180] [MV]No Audio Buffer to wirte
[ 13.693507] [MV]No Audio Buffer to wirte
[ 13.701864] [MV]No Audio Buffer to wirte
For nvgpu error, it requires to know what kind of application is running and causing this problem. Are you able to provide that?
open/close camera。
Please share your full application to us so that we can reproduce. It is not possible to just know what is going on with one screenshot of your code.
Hi wayneWWW, my application is Encrypted. Can you tell me which file report this err??
nvgpu driver is public kernel source code.
