The device sometimes occur nvgpu error, as follow:
[ 5.181983] nvgpu: 57000000.gpu gk20a_pmu_isr:724 [ERR] pmu exterr intr not implemented. Clearing interrupt.
[ 5.193804] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:560 [ERR] <<< FALCON id-0 DEBUG INFORMATION - START >>>
[ 5.204947] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:504 [ERR] FALCON IMEM BLK MAPPING (PA->VA) (96 TOTAL):
[ 5.216007] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x00: 0x01000000 0x01000100 0x01000200 0x01000300
[ 5.227574] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x04: 0x01000400 0x01000500 0x01000600 0x01000700
[ 5.239160] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x08: 0x01000800 0x01000900 0x01000a00 0x01000b00
[ 5.250734] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x0c: 0x01000c00 0x01000d00 0x01000e00 0x01000f00
[ 5.262317] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x10: 0x01001000 0x01001100 0x01001200 0x01001300
[ 5.273873] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x14: 0x01001400 0x01001500 0x01001600 0x01002d00
[ 5.285458] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x18: 0x01002e00 0x01002f00 0x01003000 0x01003100
[ 5.297016] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x1c: 0x01001c00 0x01001d00 0x01001e00 0x01001f00
[ 5.308604] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x20: 0x01002000 0x01002100 0x01002200 0x01004b00
[ 5.320072] [dhd] dhd_conf_set_txglom_params : txglom_mode=multi-desc
[ 5.320074] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0
[ 5.320076] [dhd] dhd_conf_set_txglom_params : txinrx_thres=128, dhd_txminmax=-1
[ 5.320078] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300
[ 5.320083] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-1
[ 5.355962] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x24: 0x01004c00 0x01004d00 0x01004e00 0x01004f00
[ 5.367538] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x28: 0x01005000 0x01005100 0x01002300 0x01002400
[ 5.379105] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x2c: 0x01002500 0x01003200 0x01003300 0x01003400
[ 5.386634] [dhd] dhd_conf_map_country_list : CN/38
[ 5.386636] [dhd] dhd_conf_set_country : set country CN, revision 38
[ 5.391627] [dhd] dhd_conf_set_country : Country code: CN (CN/38)
[ 5.407983] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x30: 0x01003500 0x01003600 0x01003700 0x01003800
[ 5.410684] [dhd-wlan0] wl_android_wifi_on : Success
[ 5.424505] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x34: 0x01003900 0x01003a00 0x01003b00 0x01003c00
[ 5.436079] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x38: 0x01003d00 0x01003e00 0x01003f00 0x01004000
[ 5.447640] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x3c: 0x01004100 0x01004200 0x01004300 0x01004400
[ 5.459217] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x40: 0x01004500 0x01004600 0x01004700 0x01004800
[ 5.470781] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x44: 0x01004900 0x01004a00 0x01005200 0x01005300
[ 5.482364] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x48: 0x01005400 0x01005500 0x01005600 0x01005700
[ 5.493928] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x4c: 0x01005800 0x01005900 0x01005a00 0x01005b00
[ 5.505507] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x50: 0x01005c00 0x01005d00 0x01005e00 0x01005f00
[ 5.517073] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x54: 0x01006000 0x01006100 0x01006200 0x01006300
[ 5.528646] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x58: 0x01006400 0x01006500 0x01006600 0x01002600
[ 5.540208] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x5c: 0x01002700 0x01002800 0x01002900 0x01002c00
[ 5.551771] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:541 [ERR] PC TRACE (TOTAL 7 ENTRIES. entry 0 is the most recent branch):
[ 5.564371] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(0) : 0x0000054a
[ 5.574378] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(1) : 0x00000545
[ 5.584379] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(2) : 0x0000054e
[ 5.594385] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(3) : 0x00001041
[ 5.604385] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(4) : 0x0000012a
[ 5.614400] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(5) : 0x0000160e
[ 5.624409] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(6) : 0x00000a59
[ 5.634423] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:567 [ERR] FALCON ICD REGISTERS DUMP
[ 5.643826] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 5.652971] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 5.662121] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 5.671269] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 5.680410] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 5.689556] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 5.698697] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 5.707840] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 5.716984] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:589 [ERR] FALCON_REG_IMB : 0xff5071
[ 5.726386] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:595 [ERR] FALCON_REG_DMB : 0xff50d8
[ 5.735787] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:601 [ERR] FALCON_REG_CSW : 0x300501
[ 5.745186] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:607 [ERR] FALCON_REG_CTX : 0x0
[ 5.754160] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:613 [ERR] FALCON_REG_EXCI : 0x693
[ 5.763385] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[0] : 0xa5a5a5a5
[ 5.773398] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[1] : 0xa5a5a5a5
[ 5.783403] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[2] : 0xa5a5a5a5
[ 5.793416] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[3] : 0xa5a5a5a5
[ 5.803416] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[4] : 0xa5a5a5a5
[ 5.813430] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[5] : 0xa5a5a5a5
[ 5.823433] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:625 [ERR] FALCON REGISTERS DUMP
[ 5.832574] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:627 [ERR] falcon_falcon_os_r : 0
[ 5.841713] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:629 [ERR] falcon_falcon_cpuctl_r : 0x60
[ 5.851455] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:631 [ERR] falcon_falcon_idlestate_r : 0x0
[ 5.861387] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:633 [ERR] falcon_falcon_mailbox0_r : 0x0
[ 5.871221] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:635 [ERR] falcon_falcon_mailbox1_r : 0x0
[ 5.881052] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:637 [ERR] falcon_falcon_irqstat_r : 0x60
[ 5.890891] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:639 [ERR] falcon_falcon_irqmode_r : 0xfc24
[ 5.890899] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:641 [ERR] falcon_falcon_irqmask_r : 0x7879
[ 5.890903] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:643 [ERR] falcon_falcon_irqdest_r : 0x90372
[ 5.890906] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:645 [ERR] falcon_falcon_debug1_r : 0x10000
[ 5.890910] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:647 [ERR] falcon_falcon_debuginfo_r : 0x0
[ 5.890913] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:649 [ERR] falcon_falcon_bootvec_r : 0x3200
[ 5.890917] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:651 [ERR] falcon_falcon_hwcfg_r : 0x400cc060
[ 5.890921] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:653 [ERR] falcon_falcon_engctl_r : 0x0
[ 5.890924] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:655 [ERR] falcon_falcon_curctx_r : 0x707fffe7
[ 5.890927] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:657 [ERR] falcon_falcon_nxtctx_r : 0x707fffe7
[ 5.890931] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:659 [ERR] falcon_falcon_exterrstat_r : 0x85002efb
[ 5.890934] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:661 [ERR] falcon_falcon_exterraddr_r : 0x18405818
[ 5.890939] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(0) : 0x0
[ 5.890943] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(1) : 0x0
[ 5.890946] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(2) : 0x0
[ 5.890950] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(3) : 0x0
[ 5.890954] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(4) : 0x0
[ 5.890957] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(5) : 0x0
[ 5.890961] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(6) : 0x0
[ 5.890964] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(7) : 0x0
[ 5.890968] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(8) : 0x0
[ 5.890971] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(9) : 0x0
[ 5.890975] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(10) : 0x0
[ 5.890978] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(11) : 0x0
[ 5.890982] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(0) : 0x0
[ 5.890985] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(1) : 0x0
[ 5.890988] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(2) : 0x2a
[ 5.890992] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(3) : 0x0
[ 5.890995] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:639 [ERR] pwr_pmu_bar0_error_status_r : 0x0
[ 5.890999] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:652 [ERR] pwr_pmu_bar0_fecs_error_r : 0xbadf1201
[ 5.891002] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:655 [ERR] pwr_falcon_exterrstat_r : 0x85002efb
[ 5.891006] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:659 [ERR] pwr_falcon_exterraddr_r : 0x18405818
[ 5.891040] nvgpu: 57000000.gpu print_pmu_trace:88 [ERR] dump PMU trace buffer
[ 5.891045] nvgpu: 57000000.gpu nvgpu_pmu_dump_falcon_stats:51 [ERR] pmu state: 7
[ 5.891047] nvgpu: 57000000.gpu nvgpu_pmu_dump_falcon_stats:52 [ERR] elpg state: 0
[ 5.891051] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 5.891055] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x60
[ 5.891058] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x0
[ 5.891061] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 5.891065] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 5.891068] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 5.891071] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 5.891075] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 5.891078] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 5.891082] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 5.891085] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 5.891088] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x382
[ 5.891092] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x1
[ 5.891095] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 5.891098] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x1
[ 5.891101] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x0
[ 5.891105] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 5.891108] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 5.891111] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 5.891115] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 5.891118] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 5.891121] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 5.891124] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 5.891127] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 5.891131] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 5.891134] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 5.891137] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 5.891140] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 5.891143] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 5.891147] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 5.891150] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 5.891154] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 5.891158] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 5.891162] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 5.891165] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 5.891169] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 5.891173] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 5.891177] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 5.891202] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 5.891205] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 5.891209] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 5.891213] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 5.891216] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 5.891220] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
This is a known issue. But it shall not cause gpu problem. Just some print when booting.
we had a probelm: the device will flash a white screen sometines accompany this error.
Are you using jetson nano devkit or any kind of custom board?
we used jetson nano devkit.
Please take a video of this “white screen” issue and share it here. I am not sure why only you have such issue while other people (including myself) cannot hit it.
Also, need to tell you that this issue would not be fixed easily.
This is a low probability problem,but really exist, we reset the device 100 times, maybe find 2 or 3 white screen.
And then? What happened after you saw white screen? Would it able to get into the desktop?
It happend an “start kernel”, flash a white screen ,and then enter the desktop
Ok, sounds like not fatal. Please just take this as normal behavior.
As I said, this issue would not be easily fixed.
