[b]I am trying to develop a driver for the OnSemi AR0231 image sensor.
I am able to correctly capture raw, streaming data at 31FPS using this command:[/b]
root@tegra-ubuntu:/home/nvidia# gst-launch-1.0 nvcamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1928, height=(int)1208, format=(string)I420, framerate=(fraction)31/1' ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvoverlaysink -e
However, when I run nvgstcapture-1.0, the command fails with the following terminal output:
bitrate = 4000000
Encoder Profile = High
** Message: main:5684 iterating capture loop …
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 640 H = 480
seconds to Run = 0
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
CONSUMER: Done Success
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 214)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 317)
^C** Message: <_intr_handler:5104> User Interrupted…
Terminating the camera pipeline …
^C
Here is trace output for nvgstcapture
root@tegra-ubuntu:/home/nvidia# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 101/101 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-185 [000] ...1 265.066482: rtos_queue_peek_from_isr_failed: tstamp:8637911101 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 265.066486: rtcpu_start: tstamp:8637911884
kworker/0:2-185 [000] ...1 265.275751: rtos_queue_peek_from_isr_failed: tstamp:8642888219 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 265.275755: rtos_queue_peek_from_isr_failed: tstamp:8644207975 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 265.275756: rtcpu_start: tstamp:8644208748
kworker/0:2-185 [000] ...1 265.435647: rtos_queue_peek_from_isr_failed: tstamp:8649208842 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 265.590446: rtos_queue_peek_from_isr_failed: tstamp:8654209345 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 265.746450: rtos_queue_peek_from_isr_failed: tstamp:8659209863 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 265.954447: rtos_queue_peek_from_isr_failed: tstamp:8664210363 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 266.110448: rtos_queue_peek_from_isr_failed: tstamp:8669210867 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 266.266442: rtos_queue_peek_from_isr_failed: tstamp:8674211386 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 266.422443: rtos_queue_peek_from_isr_failed: tstamp:8679211880 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 266.578438: rtos_queue_peek_from_isr_failed: tstamp:8684212388 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 266.734464: rtos_queue_peek_from_isr_failed: tstamp:8689212908 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 266.890483: rtos_queue_peek_from_isr_failed: tstamp:8694213403 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 267.047813: rtos_queue_peek_from_isr_failed: tstamp:8699213908 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 267.202441: rtos_queue_peek_from_isr_failed: tstamp:8704214414 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 267.358445: rtos_queue_peek_from_isr_failed: tstamp:8709214923 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 267.514435: rtos_queue_peek_from_isr_failed: tstamp:8714215429 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 267.670428: rtos_queue_peek_from_isr_failed: tstamp:8719215947 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 267.826428: rtos_queue_peek_from_isr_failed: tstamp:8724216443 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 268.034429: rtos_queue_peek_from_isr_failed: tstamp:8729216949 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 268.190422: rtos_queue_peek_from_isr_failed: tstamp:8734217455 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 268.346421: rtos_queue_peek_from_isr_failed: tstamp:8739217976 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 268.502424: rtos_queue_peek_from_isr_failed: tstamp:8744218471 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 268.658418: rtos_queue_peek_from_isr_failed: tstamp:8749218976 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 268.814417: rtos_queue_peek_from_isr_failed: tstamp:8754219484 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 268.970417: rtos_queue_peek_from_isr_failed: tstamp:8759219988 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 269.126421: rtos_queue_peek_from_isr_failed: tstamp:8764220495 queue:0x0b4a3c58
kworker/0:2-185 [000] ...1 269.282413: rtos_queue_peek_from_isr_failed: tstamp:8769221006 queue:0x0b4a3c58
also, this is the dmesg output after running nvgstcapture-1.0
[ 843.454672] argus_daemon[2678]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x83000006
[ 843.464010] pgd = ffffffc054d06000
[ 843.467429] [00000000] *pgd=00000000d4d8f003, *pud=00000000d4d8f003, *pmd=0000000000000000
[ 843.477326] CPU: 5 PID: 2678 Comm: argus_daemon Not tainted 4.4.38 #5
[ 843.483767] Hardware name: quill (DT)
[ 843.487442] task: ffffffc0702ca580 ti: ffffffc172d20000 task.ti: ffffffc172d20000
[ 843.494989] PC is at 0x0
[ 843.497518] LR is at 0x7f7e74c6a0
[ 843.500880] pc : [<0000000000000000>] lr : [<0000007f7e74c6a0>] pstate: 60000000
[ 843.508305] sp : 0000007f4cffc920
[ 843.511628] x29: 0000007f4cffe9d0 x28: 0000007f78b533a0
[ 843.516972] x27: 0000007f7e763000 x26: 0000000000000005
[ 843.522308] x25: 0000007f78b53579 x24: 0000007f28006e50
[ 843.527645] x23: 0000007f28006e50 x22: 0000007f78b53560
[ 843.533003] x21: 0000000000000221 x20: 0000007f78b53468
[ 843.538339] x19: 0000007f78b53390 x18: 0000000000000000
[ 843.543677] x17: 0000007f7f1944c0 x16: 0000007f7effb540
[ 843.549031] x15: 0000007f7e781b78 x14: 6572685465727574
[ 843.554390] x13: 7061436663532f69 x12: 70612f637273206d
[ 843.559732] x11: 6f726620676e6974 x10: 0000000000000000
[ 843.565090] x9 : 000000000000000c x8 : 0000000000000062
[ 843.570424] x7 : 0000000000000000 x6 : 000000002800a570
[ 843.575765] x5 : 0000000000000000 x4 : 0000000000000002
[ 843.581095] x3 : 000000000000001f x2 : 0000000000000000
[ 843.586424] x1 : 0000000000000000 x0 : 0000007f28004200
[ 843.593254] Library at 0x0: 0x400000 /usr/sbin/argus_daemon
[ 843.598828] Library at 0x7f7e74c6a0: 0x7f7e6f9000 /usr/lib/aarch64-linux-gnu/tegra/libargus.so
[ 843.607435] vdso base = 0x7f7f36b000
[ 848.591582] set gain
[ 848.593598] imx324 2-0010: imx324_set_gain: gain reg: 0
[ 848.599100] get gainset frame rate
[ 848.602550] imx324 2-0010: imx324_set_frame_rate: val: 75497472, , frame_length: 6313
[ 848.610653] get frame lengthframe length is: set exposure
[ 848.616529] imx324 2-0010: imx324_set_exposure: val: 119837
[ 848.622294] set course time
[ 848.624923] imx324 2-0010: imx324_set_coarse_time: coarse1:3246, FL:6313
[ 848.631840] get course video time
[ 849.005758] imx324 2-0010: imx324_s_stream++ enable 0
[ 849.011032] imx324 2-0010: imx324_power_off: power off
any ideas on how to debug this?
Thanks,
Daniel
