[NVHPC 23.7] Differences to NVHPC 23.5 regarding OMPT in compiler and linker flags
Dear Mat,
NVHPC 23.7 has just released and I already did some testing in regards to our reported bugs over the last few months. Many of the bugs are fixed now which is great!
However, I noticed a small thing where I wanted to know if the change in the behavior is intended or not.
Up until now, we were using the following commands to compile an application and add OMPT to the application when we wanted to instrument it (simplified of course).
$ nvc -mp=ompt shared.c -shared -o libshared.so # This is how Score-P currently handles OMPT
$ nvc -mp main.c -c
$ nvc -mp=ompt main.o libshared.so
While this still works in NVHPC 23.7, the application behaves differently if we also use -mp=ompt to compile main.c. To illustrate this, we can look at the following example:
$ cat main.c
#include <omp-tools.h>
#include <stdio.h>
extern ompt_finalize_tool_t finalize_tool;
int
foo( int i )
    return i;
int
main( void )
#pragma omp parallel
#pragma omp for
        for ( int i = 1; i < 5; i++ )
            foo( i );
    finalize_tool();
    return 1;
$ cat shared.c
#include <stdlib.h>
#include <stdio.h>
static int                  ws_loop_end_reached = 0;
static int                  initialized         = 0;
void
callback_ompt_work( ompt_work_t           work_type,
                    ompt_scope_endpoint_t endpoint,
                    ompt_data_t*          parallel_data,
                    ompt_data_t*          task_data,
                    uint64_t              count,
                    const void*           codeptr_ra )
    if ( endpoint == ompt_scope_end )
        ws_loop_end_reached = 1;
static int
ompt_initialize( ompt_function_lookup_t lookup,
                 int                    initial_device_num,
                 ompt_data_t*           tool_data )
    ompt_set_callback_t set_cb = ( ompt_set_callback_t )lookup( "ompt_set_callback" );
    if ( !set_cb )
        _Exit( 3 ); /* Tool got initialized but lookup of runtime-entry-point ompt_set_callback failed. */
    finalize_tool = ( ompt_finalize_tool_t )lookup( "ompt_finalize_tool" );
    if ( !finalize_tool )
        _Exit( 4 ); /* Tool got initialized but lookup of runtime-entry-point ompt_finalize_tool failed. */
    ompt_set_result_t result;
    result = set_cb( ompt_callback_work, ( ompt_callback_t )&callback_ompt_work );
    if ( result != ompt_set_always )
        _Exit( 5 ); /* Tool got initialized but work cb couldn't be registered. */
    initialized = 1;
    return 1; /* non-zero indicates success for OMPT runtime. */
static void
ompt_finalize( ompt_data_t* tool_data )
    if ( initialized == 1 )
        if ( ws_loop_end_reached == 1 )
            _Exit( 0 ); /* Tool got initialized and finalized. */
        _Exit( 2 );     /* Tool got initialized and finalized but ws_loop_end was not reached. */
ompt_start_tool_result_t*
ompt_start_tool( unsigned int omp_version,                           /* == _OPENMP */
                 const char*  runtime_version )
    printf("Start tool\n");
    static ompt_start_tool_result_t ompt_start_tool_result = { &ompt_initialize,
                                                               &ompt_finalize,
                                                               ompt_data_none };
    return &ompt_start_tool_result;
$ nvc -mp main.c -c
$ ./a.out; echo $?
Start tool
2
$ nvc -mp=ompt,multicore main.c -c
$ ./a.out; echo $?
Start tool
0
Without adding -mp=ompt to the compile flags, we see the work-end issue which was also present in previous NVHPC versions. If we add the flag, the issue is gone. My question is: Is this behavior intended and going forward, can we expect that we need to also add -mp=ompt to the compile flags to use OMPT for user applications?
Hi Jan,
Yes, the the -mp=ompt flag is needed when using OMPT. At compile time, there’s a slightly different code generation and at link, we’ll use a different runtime library. I believe the reasoning on not using a single runtime was due to some overhead needed for OMPT which we didn’t want to include in the main nvomp library.
Glad things are working now, but if you find additional issues, let us know and we’ll submit an issue report.
Thanks,
Mat
Thanks for the quick response! Yeah, adding additional checks if OMPT is active certainly increases the overhead. I can completely understand why you‘re doing this.
However, I was not aware that you use different code generation during compliation, hence the question 😄
The main difference in the code gen is that we generate a __kmpc_for_static_fini call when compiled with `-mp=ompt’. When OMPT is disabled that function is empty so do not generate it.
