NVHPC 26.9 - Fail during OpenBLAS 0.3.34 build
Hello, I was building OpenBLAS 0.3.34 with the latest NVHPC release, and faced the following error message during the build :
make[2]: Entering directory '/software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/OpenBLAS-0.3.34.nvc-26.9.build'
[ 84%] Building C object kernel/CMakeFiles/kernel.dir/CMakeFiles/sgemv_t.c.o
cd /software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/OpenBLAS-0.3.34.nvc-26.9.build/kernel && /software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/nvhpc_2026_269_Linux_x86_64_cuda_multi.prefix/Linux_x86_64/26.9/compilers/bin/nvc -DUSE_GEMM3M -I/software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/OpenBLAS-0.3.34 -I/software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/OpenBLAS-0.3.34.nvc-26.9.build -DHAVE_C11 -tp px -march=sapphirerapids -mavx2 -mavx -msse -msse2 -msse3 -mssse3 -msse4.1 -fPIC
-DSMALL_MATRIX_OPT -DNO_WARMUP -DMAX_CPU_NUMBER=256 -DMAX_PARALLEL_NUMBER=1 -DMAX_STACK_ALLOC=2048 -DNO_AFFINITY -DVERSION="\"0.3.34\"" -DBUILD_SINGLE -DBUILD_DOUBLE -DBUILD_COMPLEX -DBUILD_COMPLEX16 -fast -O3 -DNDEBUG -MD -MT kernel/CMakeFiles/kernel.dir/CMakeFiles/sgemv_t.c.o -MF CMakeFiles/kernel.dir/CMakeFiles/sgemv_t.c.o.d -o CMakeFiles/kernel.dir/CMakeFiles/sgemv_t.c.o -c /software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/OpenBLAS-0.3.34.nvc-26.9.build/kernel/CMakeFiles/sgemv_t.c
PLEASE submit a bug report to https://github.com/llvm/llvm-project/issues/ and include the crash backtrace and instructions to reproduce the bug.
Stack dump:
0.      Program arguments: /software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/nvhpc_2026_269_Linux_x86_64_cuda_multi.prefix/Linux_x86_64/26.9/compilers/share/llvm/bin/opt --passes=default<O3> --nvhpc-consider-undef=true --nvhpc-reassoc=true --nvhpc-canonicalize-gep=true --nvhpc-phi-opt=true --nvhpc-store-opt=true --nvhpc-unswitch-loops-with-trip-count=2 --nvhpc-slp-v2fp-gather-gate=true --nvhpc-keep-int-mul-add-alt=true --nvhpc-reject-tiny-copyable-identity=true --nvhpc-reject-buildvec-horiz-reduce=true --nvhpc-slp-v2fp-gather-reject-lo=13 --nvhpc-slp-v2fp-gather-reject-hi=18 --nvhpc-fptrunc-opt=true --nvhpc-no-sink-phi-loads-same-base=true --nvhpc-fold-nextafter=true --nvhpc-lane-group-gather=true --nvhpc-load-store-opt=true --nvhpc-masked-compress-cost=true --nvhpc-slp-insertelt-vl=true --nvhpc-x86-partial-reduction=true --nvhpc-maximize-bandwidth-for-partial-reductions=true --nvhpc-disable-rewrite-tree-merge=true --nvhpc-align-stack-for-func-spec=true --denormal-fp-math=positive-zero --nvhpc-finite-opts=false --nvhpc-unswitch-loops-with-trip-count=2 --nvhpc-phi-fold=true --nvhpc-masked-load-opt=true --nvhpc-has-mixed-const-intrin=true --nvhpc-tree-cost-adjust=true --nvhpc-defer-fma-zero-fold=true --nvhpc-enable-return-slot-move=true --nvhpc-check-tli-mapping-signature=true -mcpu=sapphirerapids /tmp/nvc9l45e3TAz2OiU.ll -S -o /tmp/nvcLl45eVCqxtqPv.llvm
1.      Running pass "ipsccp" on module "/tmp/nvc9l45e3TAz2OiU.ll"
Stack dump without symbol names (ensure you have llvm-symbolizer in your PATH or set the environment var `LLVM_SYMBOLIZER_PATH` to point to it):
0  opt       0x000055d0723433e8 llvm::sys::PrintStackTrace(llvm::raw_ostream&, int) + 40
1  opt       0x000055d072340e05 llvm::sys::RunSignalHandlers() + 293
2  opt       0x000055d072344116
3  libc.so.6 0x00007f282c23fb30
4  opt       0x000055d07000d25d
5  opt       0x000055d07000cddd
6  opt       0x000055d070017716
7  opt       0x000055d0700091cf
8  opt       0x000055d0700072dc
9  opt       0x000055d0700145e7
10 opt       0x000055d071a39f61 llvm::CodeMetrics::analyzeBasicBlock(llvm::BasicBlock const*, llvm::TargetTransformInfo const&, llvm::SmallPtrSetImpl<llvm::Value const*> const&, bool, llvm::Loop const*) + 1377
11 opt       0x000055d0707b8748 llvm::FunctionSpecializer::run() + 440
12 opt       0x000055d070796b32 llvm::IPSCCPPass::run(llvm::Module&, llvm::AnalysisManager<llvm::Module>&) + 1362
13 opt       0x000055d07219e3b9 llvm::PassManager<llvm::Module, llvm::AnalysisManager<llvm::Module>>::run(llvm::Module&, llvm::AnalysisManager<llvm::Module>&) + 313
14 opt       0x000055d06fcb22f2 llvm::runPassPipeline(llvm::StringRef, llvm::Module&, llvm::TargetMachine*, llvm::TargetLibraryInfoImpl*, llvm::ToolOutputFile*, llvm::ToolOutputFile*, llvm::ToolOutputFile*, llvm::StringRef, llvm::ArrayRef<llvm::PassPlugin>, llvm::ArrayRef<std::function<void (llvm::PassBuilder&)>>, llvm::opt_tool::OutputKind, llvm::opt_tool::VerifierKind, bool, bool, bool, bool, bool, bool, bool, bool) + 14498
15 opt       0x000055d06fca706b optMain + 10731
16 libc.so.6 0x00007f282c22a610
17 libc.so.6 0x00007f282c22a6c0 __libc_start_main + 128
18 opt       0x000055d06fca0c0e _start + 46
nvc-Fatal-/software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/nvhpc_2026_269_Linux_x86_64_cuda_multi.prefix/Linux_x86_64/26.9/compilers/share/llvm/bin/opt TERMINATED by signal 11
make[2]: *** [kernel/CMakeFiles/kernel.dir/build.make:1299: kernel/CMakeFiles/kernel.dir/CMakeFiles/sgemv_t.c.o] Error 2
make[2]: Leaving directory '/software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/OpenBLAS-0.3.34.nvc-26.9.build'
make[1]: *** [CMakeFiles/Makefile2:7831: kernel/CMakeFiles/kernel.dir/all] Error 2
make[1]: Leaving directory '/software/stack/cepp/.bmorvana-tests/openblas-nvhpc-26.9-repro/OpenBLAS-0.3.34.nvc-26.9.build'
make: *** [Makefile:146: all] Error 2
I created a reproducer here : GitHub - antoine-morvan/openblas-nvhpc-26.9-repro · GitHub
Everything builds fine with NVHPC 26.5 and older, as well as with other compilers (including recent LLVM releases).
Best,
Antoine.
Hi Antoine and thanks for the report!
I was able to reproduce the issue here and filed TPR #39125. We’ll have engineering investigate.
The issue appears to be specific when targeting Sapphire Rapids or GrandRapids architectures when processing the “_mm256_maskz_loadu_ps” intrinsic. Hence, one possible work around is to target an earlier architecture such as “-tp skylake-avx512”.
-Mat
