Here is a small example to demonstrate the issue: if I create an empty CMake project that tries to find and use system Readline library:
$ cat CMakeLists.txt
project (TestCase C)
cmake_minimum_required (VERSION 2.8)
message(STATUS "CMAKE_LIBRARY_ARCHITECTURE :: ${CMAKE_LIBRARY_ARCHITECTURE}")
find_path(Readline_ROOT_DIR NAMES include/readline/readline.h)
find_path(Readline_INCLUDE_DIR NAMES readline/readline.h HINTS ${Readline_ROOT_DIR}/include)
message(INFO "--> ${Readline_INCLUDE_DIR} :: ${CMAKE_LIBRARY_ARCHITECTURE}")
find_library(Readline_LIBRARY NAMES readline HINTS ${Readline_ROOT_DIR}/lib)
message(INFO "--> ${Readline_LIBRARY} :: ${Readline_LIBRARY}")
Compiling with GCC gives:
$ cmake . -DCMAKE_C_COMPILER=gcc
-- CMAKE_LIBRARY_ARCHITECTURE :: x86_64-linux-gnu
INFO--> /usr/include :: x86_64-linux-gnu
INFO--> /usr/lib/x86_64-linux-gnu/libreadline.so :: /usr/lib/x86_64-linux-gnu/libreadline.so
But with NVHPC compilers we get following:
$ cmake . -DCMAKE_C_COMPILER=nvc
INFO--> Readline_LIBRARY-NOTFOUND :: Readline_LIBRARY-NOTFOUND
i.e. CMAKE_LIBRARY_ARCHITECTURE is not and libraries are not found correctly.
This has been reported earlier on stackoverflow[1] and this readhat issue describes how subdir triplets from compiler is used to detect CMAKE_LIBRARY_ARCHITECTURE.
As this causes issue only with NVHPC compilers, this is something could be improved?
By the way, I am not able to reproduce this issue with CMake 3.21 but with CMake <=3.19 which is common on many platforms including Ubuntu 20.
[1] linux - CMake: find_library result depends on selected compiler? - Stack Overflow
[2] 1531678 – CMAKE_LIBRARY_ARCHITECTURE is empty
