I am using arducam ar0234 usb camera for my jetson nano development board, as soon as i run command to read video frame from usb camera camera feed runs normally with normal fps but whole system slows down, not able to use mouse and keyboard
Hi santhusannthu8,
This topic is about Nsight Graphics, and that’s for development tools. I will move this post under some other topic.
An
Which JetPack SW you used?
Can you use the Tegrastate to check the system status?
i am using jetpack version of 4.6.4
tegrastats gives following output
RAM 1613/3956MB (lfb 137x4MB) SWAP 0/4096MB (cached 0MB) CPU [2%@1224,0%@1224,2%@1224,0%@1224] EMC_FREQ 0% GR3D_FREQ 0% PLL@25.5C CPU@26.5C PMIC@50C GPU@25.5C AO@34C thermal@26.25C
RAM 1613/3956MB (lfb 137x4MB) SWAP 0/4096MB (cached 0MB) CPU [6%@1224,4%@1224,4%@1224,5%@1224] EMC_FREQ 0% GR3D_FREQ 16% PLL@26C CPU@26.5C PMIC@50C GPU@26C AO@34C thermal@26.5C
any suggestions?
Sorry for the late response.
