Hey there,
So I just installed a new Quadro K4200 on my Ubuntu 14.04 workstation and was trying to get my 3D vision Kit 2 to work. When the window manager boots all you can see are vertical green, black and yellow lines (like a giant barcode).
I am using Xubuntu (Xfce window manager) with no composite extensions with NVidia driver 352.63.
I have attached a screen shot of what comes up on my monitor and also the Nvidia bug report which has all the X.org outputs.
And my Xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 352.63 (buildmeister@vm-ubuntu1404-x64-001) Thu Nov 12 11:01:03 PST 2015
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Ancor Communications Inc VG248"
HorizSync 30.0 - 160.0
VertRefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "Quadro K4200"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "10"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "1920x1080_120 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
I’m running it straight out of the DVI (dual link) port of the card to an ASUS VG248QE monitor. Just so you know, the monitor works fine when i change the stereo option in the xorg.conf file back to 0. It also doesn’t seem to change if I use the Displayport 1.2 instead of the DVI, the only thing that changes is the pattern on the screen.
Any help would be greatly appreciated.
cheers
nvidia-bug-report.log.gz (209 KB)
