System information
Distribution: Debian GNU/Linux forky/testing
Kernel: 7.2.11+deb14-amd64
NVIDIA Driver: 595.104.02 (Open Kernel Module)
GPU: NVIDIA GB203
Desktop: Cinnamon 6.6.9, X11
IOMMU: Intel VT-d, translated DMA domain
Problem description
The system experienced a severe GPU hang, resulting in an unresponsive graphical environment.
The NVIDIA kernel driver repeatedly reported Xid 109 (CTX SWITCH TIMEOUT), accompanied by Intel VT-d DMA write faults and GSP-related failures.
The GPU did not recover, and the watchdog continued reporting that the GPU was probably locked.
Relevant kernel messages
DMAR: [DMA Write NO_PASID] Request device [0000:01:00.0]
fault addr 0xf6d7f000 [fault reason 0x05]
PTE Write access is not set
NVRM: GPU0 nvCheckFailedNoLog:
Check failed: pKernelChannel != NULL @ kernel_gsp.c:640
NVRM: GPU0 _kgspProcessRpcEvent:
Failed to process received event 0x1004 (RC_TRIGGERED)
from GPU0: status=0x21
NVRM: krcWatchdog_IMPL:
RC watchdog: GPU is probably locked!
NVRM: Xid (PCI:0000:01:00): 109,
channel 0x00000005,
errorString CTX SWITCH TIMEOUT,
Info 0x54005
The errors recurred approximately every 16–17 seconds.
IOMMU configuration
The kernel reports:
iommu: Default domain type: Translated
iommu: DMA domain TLB invalidation policy: lazy mode
DMAR: dmar0: Using Queued invalidation
No custom IOMMU kernel parameters were configured.
Questions
Could this indicate a regression in the NVIDIA 595 Open Kernel Module or GSP firmware?
Could the repeated DMA write faults be related to invalid DMA mappings or GPU recovery failures?
Are there known compatibility issues between this driver version, Intel VT-d, and recent Linux kernels?
I can provide the NVIDIA bug report and full kernel logs for further investigation.
nvidia-bug-report.log.gz -
kernel-crash.log -
Kernel and NVIDIA module version information
nvidia-bug-report.log.gz (886.8 KB)
kernel-version.txt (103 Bytes)
kernel-crash.log (227.2 KB)
gpu-pci.txt (254 Bytes)
dkms-status.txt (113 Bytes)
