[NVIDIA A100 PCIe 40GB] Power Consumption Limited to ~130W Under Load
Hi everyone,
I have an NVIDIA A100 PCIe 40GB GPU installed in a Supermicro server, and I have noticed something unusual regarding its power consumption.
According to NVIDIA’s specifications, the A100 PCIe 40GB has a maximum power consumption of 250W. However, during my compute benchmarks, the reported power consumption remained around 125–130W, even when GPU utilization reached 100%.
My system configuration:
  • GPU: NVIDIA A100 PCIe 40GB
  • CPU: AMD EPYC 7543
  • Motherboard: Supermicro H12SSL-i
  • OS: Ubuntu 26.04.1 LTS
  • NVIDIA Driver: 595.91.07
  • CUDA Toolkit: 13.1
  • GPU Power Limit: 250W
Benchmark results:
  • FP16 Dense GEMM: 94.27 TFLOPS
  • FP16 continuous benchmark (30 seconds): 93.49 TFLOPS
  • FP32 GEMM: 16.75 TFLOPS
  • FP32 continuous benchmark (30 seconds): 16.58 TFLOPS
  • Maximum recorded power consumption during the monitored FP32 test: 132.53W
  • Average power consumption: 124.76W
  • Maximum GPU temperature: 48°C
  • GPU utilization: up to 100%
I also ran NVIDIA DCGM diagnostics (Levels 1, 2, and 3), and all tests passed.
The GPU power limit is configured to 250W, and I did not observe any hardware thermal or power brake slowdown flags during testing.
My questions are:
  1. Is it normal for an A100 PCIe 40GB to consume only around 130W during FP32 GEMM workloads, even at 100% GPU utilization?
  2. Are my FP16 and FP32 benchmark results consistent with a healthy A100 PCIe 40GB?
  3. What workloads or benchmarks would you recommend to determine whether the GPU can reach its expected power consumption under full load?
  4. Could a hardware issue in the GPU’s power delivery circuitry cause reduced power consumption while still allowing the GPU to pass DCGM diagnostics and deliver normal benchmark performance?
  5. Are there any specific NVIDIA tools or diagnostic indicators that could help distinguish normal power management behavior from a hardware-related power limitation?
I would appreciate any insights or recommendations.
Thank you!
