NVIDIA A100 (SXM4 → PCIe) won’t POST when both 8-pin PSU cables connected - only works with one
Hi all,
I’m building a workstation with an NVIDIA A100 80GB PCIe GPU - specifically, an SXM4-to-PCIe converted version - and running into a strange power-related POST issue. I’d love any insight from others who’ve worked with this card (especially SXM4 conversions) or with datacenter GPUs on consumer boards.
💻 System Specs:
  • Motherboard: ASUS ProArt Z790
  • CPU: Intel Core i9 (with iGPU - used for display)
  • PSU: Lian Li EDGE 1300W, 80+ Platinum
  • GPU: NVIDIA A100 80GB SXM4 converted to PCIe (PCIe bracket, 1× 8-pin power socket)
  • Cables: Using included adapter harness (dual-input to single 8-pin)
🧪 What works:
  • BIOS boots perfectly with no GPU
  • BIOS boots with A100 installed and only one 8-pin power cable connected
  • Display from motherboard HDMI works fine (BIOS set to iGPU, Above 4G enabled, Gen4 and Gen3 both tested)
What fails:
  • As soon as both PSU cables are connected to the adapter - system halts at white VGA Q-LED on motherboard. No POST, no display.
  • Tried multiple cable combinations, separate PCIe jacks on PSU, different slots - same result.
Suspected cause:
  • The adapter cable that came with the GPU has only 7 wires going into the 8-pin GPU-side plug: 3 yellow (12V) + 4 black (GND).
  • A full PCIe 8-pin should have 3× +12V and 5× GND. The 2 extra grounds are used for sense pins - likely the GPU detects that it’s not getting a complete connection and aborts startup.
What I’d like to know:
  • Has anyone else dealt with this issue using a converted A100?
  • Any BIOS tricks or power tricks that helped?
  • Anything I’m missing or anything else I should know?
Josh
*I know - I’m building a consumer grade pc with a data center grade GPU, I’m clearly an idiot, but if you can spend a few minutes to help this idiot out I will be eternally grateful.
