Nvidia AGX Orin Carrier Card design files BoM mismatch
Dear Team,
I was checking the Nvida AGX Orin Carrier card design files and there are lot of mismatch found in BoM with respect to the schematics file. Some of the mounted components in the schematics are not present in the BoM. Could you please share the final proper version of design files. This will be really helpful.
Best Regards,
Vyshnav Krishnan
Would you please be more specific of what files are mismatch?
Hi Kayccc,
I have downloaded the Jetson AGX Orin carrier card design files. When I compared the BoM with the schematics, some of the mounted parts in the schematics (P3737-A05 Concept schematics) is not found in BoM (P3737_A05_BoM). Below are the examples.
  1. Connector J3 is mounted in the schematics but not found in BoM
  2. U100 and U101 are mounted in schematics but in BoM its not present.
Looks like there is some issue happened in BoM export. Could you please share the final version of schematics and BoM with all part details included.
Best Regards,
Vyshnav Krishnan
Hi Kayccc,
Please find the attached snap. These many items are missing in the BoM, which are shown as mounted in the schematics. Kindly check and share the final BoM and schematics.
Best Regards,
Vyshnav Krishnan
Dear @kayccc ,
We are waiting for your response to proceed further.
Best Regards,
Vyshnav Krishnan
Hi, we are checking this internally, will update once available.
Actually, the MPN of those parts are included in the BOM but the RefDes were deleted by mistake. The BOM file will be updated. Before that, you can refer to schematic for correct info. Thanks.
Hi @Trumany , Thank you for the update. But it will be great if you could provide updated final BoM. Thanks
As said, before that, please take schematic as reference.
