NVIDIA AGX Orin,Jetson6.0 can‘t find 4G/5G TI
NVIDIA AGX ORIN, I am using Ubuntu 20.04. When I plug in my wireless network card with USB interface, it can be detected and I can access the internet normally. When I upgrade to Jetson 6. x, the system is upgraded to Ubuntu 22.04, and at this time, the USB network card I inserted cannot be detected. Using command lsUSB can detect the insertion, but using ifconfig cannot see the new network card added. What should I do?
Please check if there is additional kernel configs required for the device. Jetpack 6 is aligned to upstream kernel and you would need to manually enable some configs.
