We are trying to get CY15B104QN spi-fram with nvmem subsystem. When we use atmel at25 eeprom driver, we always read FF from the chip. When we try to debug using spi-tools without the driver, if we read with default bits-per-word parameter which is 8 we always read FF. We observed that the spi controller does not drive clock more than 8 bits. If I set bits-per-word to 16 on spi-tools (spi-pipe command) I can read the device id. What could be the problem here? The IC is connected to the SPI1.
Do you have any concern to use bits-per-word as 16?
In 16-bit mode, the command and address bytes are grouped into the same SPI transfer, ensuring they are sent in one continuous transaction. This prevents chip-select(CS) from toggling or introducing gaps between bytes, which could otherwise cause the device to misinterpret the sequence and lead to data loss.
