I’m trying to install the necessary prerequisite with the instruction below:
https://forums.developer.nvidia.com/t/object-detection-with-jetson-nano/198189/9
However, when I run $bash install_torch_v1.9.sh I am facing this extension error;
[RuntimeError: Error compiling objects for extension]
Allowing ninja to set a default number of workers… (overridable by setting the environment variable MAX_JOBS=N)
[1/14] /usr/local/cuda/bin/nvcc -DWITH_CUDA -I/tmp/torchvision/torchvision/csrc -I/home/ai/.local/lib/python3.6/site-packages/torch/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/TH -I/home/ai/.local/lib/python3.6/site-packages/torch/include/THC -I/usr/local/cuda/include -I/usr/include/python3.6m -c -c /tmp/torchvision/torchvision/csrc/ops/cuda/ps_roi_pool_kernel.cu -o /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/cuda/ps_roi_pool_kernel.o -D__CUDA_NO_HALF_OPERATORS__ -D__CUDA_NO_HALF_CONVERSIONS__ -D__CUDA_NO_BFLOAT16_CONVERSIONS__ -D__CUDA_NO_HALF2_OPERATORS__ --expt-relaxed-constexpr --compiler-options ‘’“'”‘-fPIC’“'”‘’ -DTORCH_API_INCLUDE_EXTENSION_H ‘-DPYBIND11_COMPILER_TYPE=“gcc"’ '-DPYBIND11_STDLIB="libstdcpp"’ '-DPYBIND11_BUILD_ABI="cxxabi1011"’ -DTORCH_EXTENSION_NAME=C -D_GLIBCXX_USE_CXX11_ABI=1 -gencode=arch=compute_53,code=compute_53 -gencode=arch=compute_53,code=sm_53 -std=c++14
FAILED: /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/cuda/ps_roi_pool_kernel.o
/usr/local/cuda/bin/nvcc -DWITH_CUDA -I/tmp/torchvision/torchvision/csrc -I/home/ai/.local/lib/python3.6/site-packages/torch/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/TH -I/home/ai/.local/lib/python3.6/site-packages/torch/include/THC -I/usr/local/cuda/include -I/usr/include/python3.6m -c -c /tmp/torchvision/torchvision/csrc/ops/cuda/ps_roi_pool_kernel.cu -o /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/cuda/ps_roi_pool_kernel.o -D__CUDA_NO_HALF_OPERATORS -D__CUDA_NO_HALF_CONVERSIONS -D__CUDA_NO_BFLOAT16_CONVERSIONS__ -D__CUDA_NO_HALF2_OPERATORS__ --expt-relaxed-constexpr --compiler-options ‘’”’“‘-fPIC’”‘"’’ -DTORCH_API_INCLUDE_EXTENSION_H ‘-DPYBIND11_COMPILER_TYPE=“gcc"’ '-DPYBIND11_STDLIB="libstdcpp"’ '-DPYBIND11_BUILD_ABI="cxxabi1011"’ -DTORCH_EXTENSION_NAME=C -D_GLIBCXX_USE_CXX11_ABI=1 -gencode=arch=compute_53,code=compute_53 -gencode=arch=compute_53,code=sm_53 -std=c++14
Killed
[2/14] c++ -MMD -MF /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/deform_conv2d.o.d -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DWITH_CUDA -I/tmp/torchvision/torchvision/csrc -I/home/ai/.local/lib/python3.6/site-packages/torch/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/TH -I/home/ai/.local/lib/python3.6/site-packages/torch/include/THC -I/usr/local/cuda/include -I/usr/include/python3.6m -c -c /tmp/torchvision/torchvision/csrc/ops/deform_conv2d.cpp -o /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/deform_conv2d.o -DTORCH_API_INCLUDE_EXTENSION_H ‘-DPYBIND11_COMPILER_TYPE=“gcc"’ '-DPYBIND11_STDLIB="libstdcpp"’ '-DPYBIND11_BUILD_ABI="cxxabi1011"’ -DTORCH_EXTENSION_NAME=C -D_GLIBCXX_USE_CXX11_ABI=1 -std=c++14
[3/14] c++ -MMD -MF /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/interpolate_aa.o.d -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DWITH_CUDA -I/tmp/torchvision/torchvision/csrc -I/home/ai/.local/lib/python3.6/site-packages/torch/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/TH -I/home/ai/.local/lib/python3.6/site-packages/torch/include/THC -I/usr/local/cuda/include -I/usr/include/python3.6m -c -c /tmp/torchvision/torchvision/csrc/ops/interpolate_aa.cpp -o /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/interpolate_aa.o -DTORCH_API_INCLUDE_EXTENSION_H '-DPYBIND11_COMPILER_TYPE="gcc"’ '-DPYBIND11_STDLIB="libstdcpp"’ '-DPYBIND11_BUILD_ABI="cxxabi1011"’ -DTORCH_EXTENSION_NAME=C -D_GLIBCXX_USE_CXX11_ABI=1 -std=c++14
[4/14] /usr/local/cuda/bin/nvcc -DWITH_CUDA -I/tmp/torchvision/torchvision/csrc -I/home/ai/.local/lib/python3.6/site-packages/torch/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/TH -I/home/ai/.local/lib/python3.6/site-packages/torch/include/THC -I/usr/local/cuda/include -I/usr/include/python3.6m -c -c /tmp/torchvision/torchvision/csrc/ops/cuda/roi_pool_kernel.cu -o /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/cuda/roi_pool_kernel.o -D__CUDA_NO_HALF_OPERATORS -D__CUDA_NO_HALF_CONVERSIONS -D__CUDA_NO_BFLOAT16_CONVERSIONS -D__CUDA_NO_HALF2_OPERATORS --expt-relaxed-constexpr --compiler-options ‘’”’“‘-fPIC’”‘"’’ -DTORCH_API_INCLUDE_EXTENSION_H '-DPYBIND11_COMPILER_TYPE="gcc"’ '-DPYBIND11_STDLIB="libstdcpp"’ '-DPYBIND11_BUILD_ABI="cxxabi1011"’ -DTORCH_EXTENSION_NAME=C -D_GLIBCXX_USE_CXX11_ABI=1 -gencode=arch=compute_53,code=compute_53 -gencode=arch=compute_53,code=sm_53 -std=c++14
[5/14] /usr/local/cuda/bin/nvcc -DWITH_CUDA -I/tmp/torchvision/torchvision/csrc -I/home/ai/.local/lib/python3.6/site-packages/torch/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/TH -I/home/ai/.local/lib/python3.6/site-packages/torch/include/THC -I/usr/local/cuda/include -I/usr/include/python3.6m -c -c /tmp/torchvision/torchvision/csrc/ops/cuda/ps_roi_align_kernel.cu -o /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/cuda/ps_roi_align_kernel.o -D__CUDA_NO_HALF_OPERATORS -D__CUDA_NO_HALF_CONVERSIONS -D__CUDA_NO_BFLOAT16_CONVERSIONS -D__CUDA_NO_HALF2_OPERATORS --expt-relaxed-constexpr --compiler-options ‘’”’“‘-fPIC’”‘"’’ -DTORCH_API_INCLUDE_EXTENSION_H ‘-DPYBIND11_COMPILER_TYPE=“gcc"’ '-DPYBIND11_STDLIB="libstdcpp"’ '-DPYBIND11_BUILD_ABI="cxxabi1011"’ -DTORCH_EXTENSION_NAME=C -D_GLIBCXX_USE_CXX11_ABI=1 -gencode=arch=compute_53,code=compute_53 -gencode=arch=compute_53,code=sm_53 -std=c++14
[6/14] /usr/local/cuda/bin/nvcc -DWITH_CUDA -I/tmp/torchvision/torchvision/csrc -I/home/ai/.local/lib/python3.6/site-packages/torch/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include -I/home/ai/.local/lib/python3.6/site-packages/torch/include/TH -I/home/ai/.local/lib/python3.6/site-packages/torch/include/THC -I/usr/local/cuda/include -I/usr/include/python3.6m -c -c /tmp/torchvision/torchvision/csrc/ops/cuda/deform_conv2d_kernel.cu -o /tmp/torchvision/build/temp.linux-aarch64-3.6/tmp/torchvision/torchvision/csrc/ops/cuda/deform_conv2d_kernel.o -D__CUDA_NO_HALF_OPERATORS -D__CUDA_NO_HALF_CONVERSIONS -D__CUDA_NO_BFLOAT16_CONVERSIONS__ -D__CUDA_NO_HALF2_OPERATORS__ --expt-relaxed-constexpr --compiler-options ‘’”’“‘-fPIC’”‘"’’ -DTORCH_API_INCLUDE_EXTENSION_H ‘-DPYBIND11_COMPILER_TYPE=“_gcc”’ ‘-DPYBIND11_STDLIB=“_libstdcpp”’ ‘-DPYBIND11_BUILD_ABI=“_cxxabi1011”’ -DTORCH_EXTENSION_NAME=_C -D_GLIBCXX_USE_CXX11_ABI=1 -gencode=arch=compute_53,code=compute_53 -gencode=arch=compute_53,code=sm_53 -std=c++14
ninja: build stopped: subcommand failed.
File “/home/ai/.local/lib/python3.6/site-packages/torch/utils/cpp_extension.py”, line 1672, in _run_ninja_build
env=env)
File “/usr/lib/python3.6/subprocess.py”, line 438, in run
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command ‘[‘ninja’, ‘-v’]’ returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File “setup.py”, line 488, in
‘clean’: clean,
File “/usr/local/lib/python3.6/dist-packages/setuptools/init.py”, line 163, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python3.6/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/usr/lib/python3.6/distutils/dist.py”, line 955, in run_commands
self.run_command(cmd)
File “/usr/lib/python3.6/distutils/dist.py”, line 974, in run_command
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install.py”, line 67, in run
self.do_egg_install()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install.py”, line 109, in do_egg_install
self.run_command(‘bdist_egg’)
File “/usr/lib/python3.6/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/bdist_egg.py”, line 175, in run
cmd = self.call_command(‘install_lib’, warn_dir=0)
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/bdist_egg.py”, line 161, in call_command
self.run_command(cmdname)
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install_lib.py”, line 11, in run
self.build()
File “/usr/lib/python3.6/distutils/command/install_lib.py”, line 109, in build
self.run_command(‘build_ext’)
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/build_ext.py”, line 87, in run
_build_ext.run(self)
File “/home/ai/.local/lib/python3.6/site-packages/Cython/Distutils/old_build_ext.py”, line 186, in run
_build_ext.build_ext.run(self)
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 339, in run
self.build_extensions()
File “/home/ai/.local/lib/python3.6/site-packages/torch/utils/cpp_extension.py”, line 709, in build_extensions
build_ext.build_extensions(self)
File “/home/ai/.local/lib/python3.6/site-packages/Cython/Distutils/old_build_ext.py”, line 195, in build_extensions
_build_ext.build_ext.build_extensions(self)
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 448, in build_extensions
self._build_extensions_serial()
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 473, in _build_extensions_serial
self.build_extension(ext)
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/build_ext.py”, line 208, in build_extension
_build_ext.build_extension(self, ext)
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 533, in build_extension
depends=ext.depends)
File “/home/ai/.local/lib/python3.6/site-packages/torch/utils/cpp_extension.py”, line 539, in unix_wrap_ninja_compile
with_cuda=with_cuda)
File “/home/ai/.local/lib/python3.6/site-packages/torch/utils/cpp_extension.py”, line 1360, in _write_ninja_file_and_compile_objects
error_prefix=‘Error compiling objects for extension’)
File “/home/ai/.local/lib/python3.6/site-packages/torch/utils/cpp_extension.py”, line 1682, in _run_ninja_build
raise RuntimeError(message) from e
I’d really appreciate some pointers to the cause of this issue, since I’ve been trying everything I could think of, to no avail.
Thank you.
