Title: NVIDIA API Chat Completions Timeout in GitHub Actions — GLM-5.3-Flash
Hello NVIDIA Developer Support,
I am troubleshooting inconsistent behavior with the NVIDIA hosted inference API.
Model: “z-ai/glm-5.3-flash”
API endpoint: “https://integrate.api.nvidia.com/v1/chat/completions”
Environment: GitHub Actions, Python urllib
API key source: NVIDIA Build (“build.nvidia.com”)
Observed results:
1. “GET /v1/models” succeeds with HTTP 200 and returns the model catalog.
2. The same model successfully responds to a short prompt in NVIDIA Build Playground.
3. A single non-streaming chat completion request from GitHub Actions timed out after 30 seconds.
4. An earlier request from the same project timed out after 240 seconds.
5. The requests used a valid model ID, Bearer authentication, JSON content type, and a short prompt.
6. The failed requests did not produce a usable model response. Automatic retries were not used in the controlled 30-second test.
Could you help determine whether this is related to the hosted inference service, model availability, account entitlement, or differences between Playground and direct API requests?
Please advise which request diagnostics or request IDs would help identify the cause.
I have not included any API keys or other credentials.
Thank you.
