Nvidia blast -how to get tower demo (Repo broken?)
how to get blast tower demo ? where to download?
it cant be downloaded from github… maybe someone?
Hey @delphi88,
The Github repo is public, so you should be able to see this:
Click on “view raw” and your browser should download the file.
That said, Blast is not actively maintained any longer, so no guarantees.
forget to add… tried in past
PS C:\Users\strto\Downloads\blast_tools_and_samples-windows (2)> .\download_sample_resources.bat
Running packman to pull resources…
Processing project file ‘C:\Users\strto\Downloads\blast_tools_and_samples-windows (2)\samples\resources\configs\resources.xml’
Package ‘BlastSampleResources’ at version ‘22532953’ is missing from local storage.
Package 'BlastSampleResources' at version '22532953' is missing from local storage.
packman(ERROR): Unable to download file from 'https://d4i3qtqj3r0z5.cloudfront.net/BlastSampleResources%4022532953' (server returned 403)
Seems that the resources are not served any longer. You might be out of luck then. As I said, this is not actively maintained anymore.
I can check if I find some internal contact, but no promise.
I received some feedback. It seems PhysX had a similar issue:
For PhysX we had to update packman at some point for downloads to still work: PhysX SDK Releases <= 5.3.0 Packman errors when running generate_projects.bat|sh · NVIDIA-Omniverse/PhysX · Discussion #230 · GitHub
The package is actually there and publicly downloadable: https://d4i3qtqj3r0z5.cloudfront.net/BlastSampleResources%4022532953.7z
Does that help in your situation?
no
all the same
well its very strange - there are no wat no build blast now?
Hello delphi88,
I’ve updated Packman in the NVIDIAGameWorks/Blast repo, and fixed a few project generation issues along the way. After pulling the latest commit in master, the download_sample_resources.bat should work for you. (It worked for me.)
Although project generation works, the code in the NVIDIAGameWorks branch has now gone stale by the current C++ standards. We don’t plan to update this repo however; it’s being kept up for now just as an archive of the older Blast SDK.
There is a newer Blast SDK in the NVIDIA-Omniverse/PhysX github repo. Although it contains many updates to the low-level solver, including the stress solver, it does not have most of the tools nor the SampleAssetViewer. As Markus pointed out, development is not currently active in that repo.
I hope this helps,
Bryan Galdrikian
