I have been working with my Nvidia Jetson (running ubuntu 20) for multiple months and have not recently installed any updates or drivers.
When I power on the Jetson, it will show the Nvidia screen, then the text stream, then go to a black screen. There is no blinking cursor or any text, just the screen. It will turn on and off in a slow blinking pattern. If I press Ctrl+Alt+F3, it either (this varies randomly)
- Opens up the terminal for a few seconds, then returns to the same startup text screen, then goes back to blinking
- Nothing at all
I have tried every option I’ve seen for booting into recovery mode or a GRUB menu, but nothing affects the pattern I’ve described. Because of that, I cannot try any of the solutions to somewhat similar problems that are available. I have also tried restarting several times and switching the HDMI cable and monitor.
One time, randomly and un-reproduceably, it actually opened the terminal and I was able to run commands (I’m trying to fix a problem of not being able to ssh into this computer). I restarted it later, and now I’ve back to the same problem.
