NVIDIA Build Free Endpoint not responding – chat/completions fails while /models works
Hello NVIDIA team,
I am unable to use the NVIDIA Build free inference endpoints.
My NVIDIA Developer Program profile is complete and I am signed in. I generated an API key through NVIDIA Build and tested the official API example for deepseek-ai/deepseek-v4.1-flash.
Observed behavior:
  • GET https://integrate.api.nvidia.com/v1/models succeeds with HTTP 200.
  • deepseek-ai/deepseek-v4.1-flash is listed by the API and is shown on NVIDIA Build as a Free Endpoint.
  • POST https://integrate.api.nvidia.com/v1/chat/completions does not start a response and eventually times out.
  • I tested the request directly against the NVIDIA endpoint using the API key provided through NVIDIA Build.
  • I also tested through an OpenAI-compatible client, with the same inability to obtain an inference response.
  • A separate API key previously returned 401 Authentication failed for /v1/chat/completions, while /v1/models remained accessible.
  • The same behavior persists after completing my NVIDIA Developer Program profile.
I also verified that the request uses the same configuration shown in NVIDIA Build’s official example:
  • Base URL: https://integrate.api.nvidia.com/v1
  • Model: deepseek-ai/deepseek-v4.1-flash
  • Endpoint: /chat/completions
  • Bearer authentication with an NVIDIA Build API key
Could you please check whether Public API Endpoints / hosted inference access is enabled for my account or personal organization, and whether there is currently an account-side issue preventing NVIDIA Build inference requests?
I will not post my API key publicly, but I can provide non-sensitive request or account information if required.
Thank you.
