NVIDIA Build: Kimi K3 and DeepSeek API requests time out, while GPT-OSS-20B works
Hello NVIDIA Developer Support,
I am requesting help diagnosing an inference issue with NVIDIA Build. I have spent considerable time testing the official Playground and the API, and I would appreciate assistance determining whether this is a model-serving issue or an account-specific problem.
1. Environment
  • Operating system: Windows 10/11
  • Python: 3.14.2
  • HTTP client: Python requests library
  • Python virtual environment: C:\kimi_bot\.venv
  • NVIDIA API base URL: https://integrate.api.nvidia.com
  • Chat completions endpoint: POST /v1/chat/completions
2. Models affected
The following models fail to return a response in the NVIDIA Build Playground:
  • moonshotai/kimi-k3
  • deepseek-ai/deepseek-v4.1-flash (DeepSeek V4.1 Flash)
Kimi K3 also fails when called directly through the NVIDIA API.
3. A model that works
GPT-OSS-20B responds successfully in the official NVIDIA Build Playground.
For example, I submitted the prompt:
Reply with exactly: OK
GPT-OSS-20B completed its reasoning and returned OK.
This is an important distinction: at least one hosted model works correctly in the same NVIDIA Build environment, while Kimi K3 and DeepSeek V4.1 Flash appear to hang.
4. API catalog verification
I tested the model catalog using the following request:
GET https://integrate.api.nvidia.com/v1/models
The result was:
  • HTTP status: 200
  • moonshotai/kimi-k3 present in the returned catalog: True
Therefore, the API key is accepted for this catalog request, and Kimi K3 is listed as an available model. However, I understand that successful catalog access does not necessarily guarantee successful inference access.
5. Direct API inference test
I sent a minimal chat completion request to:
POST https://integrate.api.nvidia.com/v1/chat/completions
The request used:
  • Model: moonshotai/kimi-k3
  • Prompt: Reply with exactly: OK
  • max_tokens: 32
  • temperature: 1
  • reasoning_effort: low
  • stream: false
  • Connect timeout: 15 seconds
  • Read timeout: 90 seconds
The request did not return a response and ended with:
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='integrate.api.nvidia.com', port=443): Read timed out. (read timeout=90)
The same general problem had occurred in previous tests, including a streaming request that waited approximately 120 seconds without receiving output.
6. NVIDIA Build Playground tests
I also tested Kimi K3 directly in the official NVIDIA Build Playground to determine whether the problem was caused by my Python code.
Kimi K3 remained stuck in the loading state and did not produce an answer.
I checked the Playground parameters:
  • Streaming: enabled
  • Reasoning effort: low
  • Temperature: 1
  • Maximum output tokens: initially 1000, subsequently reduced to 256
I submitted the short prompt:
The model still did not return a response.
DeepSeek V4.1 Flash exhibited similar hanging behavior in the Playground.
In contrast, GPT-OSS-20B successfully returned OK in the Playground.
7. API key and troubleshooting steps
I created a new NVIDIA API key and repeated the tests. The behavior did not change.
I also confirmed that the NVIDIA_API_KEY environment variable was set in the Windows Command Prompt during the tests.
The API key itself is not included in this report for security reasons.
I have not found a setting in the NVIDIA Build account interface that explicitly enables or disables “Public API Endpoints.”
8. What I need help with
Could you please investigate the following?
  1. Is there a known inference-serving incident or capacity issue affecting Kimi K3 and DeepSeek V4.1 Flash?
  2. Is my NVIDIA Build Personal Organization correctly provisioned to use hosted inference for these models?
  3. Can a model appear in GET /v1/models while its inference endpoint is unavailable or inaccessible to a particular account?
  4. Are there model-specific request parameters, endpoint requirements, or restrictions that could explain the timeouts?
  5. Is there a recommended diagnostic endpoint or request ID mechanism I can use to identify the cause?
  6. If the issue is account-specific, could you advise how to restore access?
I would like to use Kimi K3 through the NVIDIA-hosted API. I am not trying to deploy the model locally or switch to a different model.
I can provide screenshots of the Playground behavior and the Python traceback if needed.
Thank you for your help.
