Nvidia-container-cli: device error: 1: unknown device\\\\n\\\"\"": unknown
Hi
I m trying to run startDocker.sh file that I downloaded from https://ngc.nvidia.com/catalog/resources/nvidia:med:getting_started.
Below is the scripts from the sh file.
#!/bin/bash
DOCKER_IMAGE=nvcr.io/nvidia/clara-train-sdk:v3.0
DOCKER_Run_Name=claradevday
jnotebookPort=$1
GPU_IDs=$2
AIAA_PORT=$3
#################################### check if parameters are empty
if [[ -z $jnotebookPort ]]; then
jnotebookPort=8890
fi
if [[ -z $GPU_IDs ]]; then #if no gpu is passed
GPU_IDs=‘0,1,2,3’
fi
if [[ -z AIAA_PORT ]]; then AIAA_PORT=5000 fi #################################### check if name is used then exit docker ps -a|grep {DOCKER_Run_Name}
dockerNameExist=? if (({dockerNameExist}==0)) ;then
echo — dockerName {DOCKER_Run_Name} already exist echo ----------- attaching into the docker docker exec -it {DOCKER_Run_Name} /bin/bash
exit
fi
echo -----------------------------------
echo starting docker for {DOCKER_IMAGE} using GPUS {GPU_IDs}
extraFlag="-it "
cmd2run="/bin/bash"
extraFlag={extraFlag}" -p "{jnotebookPort}":8888 -p "{AIAA_PORT}":80" echo starting please run "./installDashBoardInDocker.sh" to install the lab extensions then start the jupeter lab echo once completed use web browser with token given yourip:{jnotebookPort} to access it
docker run --rm {extraFlag} \ --name={DOCKER_Run_Name}
-e NVIDIA_VISIBLE_DEVICES={GPU_IDs} \ -v {PWD}/…/:/claraDevDay/
-w /claraDevDay/scripts
–runtime=nvidia
–shm-size=1g --ulimit memlock=-1 --ulimit stack=67108864
{DOCKER_IMAGE} \ {cmd2run}
I am encountering the below error
ml@ml-GL503VM:~/Documents/claraDevDay/scripts$ ./startDocker.sh
starting docker for nvcr.io/nvidia/clara-train-sdk:v3.0 using GPUS 0,1,2,3
starting please run ./installDashBoardInDocker.sh to install the lab extensions then start the jupeter lab
once completed use web browser with token given yourip:8890 to access it
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused “process_linux.go:432: running prestart hook 1 caused \“error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: device error: 1: unknown device\\n\”””: unknown.
As I am a novice in this. Can you guide me how to troubleshoot this issue?
Hi
Thanks for your interest in Clara Train SDK.
The default parameters for the start docker is to use port 8890 and GPU_IDs=‘0,1,2,3’. It could be you only have 1 gpu so you should change this to GPU_IDs=‘0’ or run
./startDocker.sh 8890 '0'
I have the same issue. Have you solve the problem?
kindly refer to @aharouni’s post #2 on this thread. One way to figure out the GPU setup in your system would be to run nvidia-smi; for a single GPU system you may try ./startDocker.sh 8890 ‘0’; for a 2 GPU system you may try something like ./startDocker.sh 8890 ‘0,1’ etc. Hope this helps.
Thanks. able to run with ./startDocker.sh 8890 ‘0’
