hello,
After configuring MIG, I use k8s to schedule deepstream pod, and the error is as follows. Why?
Error: failed to start container “init-config”: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: device error: MIG-2ba1f3fb-acbd-5ead-9e07-58705d9fcf51: unknown device: unknown
This looks like a Deepstream related issue. We will move this post to the Deepstream forum.
Hello @1032015185 ,
Can you provide more information for your environment/setup?
Based on the above description it is difficult for us to figure out the root cause.
• DeepStream Version
• TensorRT Version
Please check your docker running status, fix the docker issue firstly.
