Nvidia Container Runtime with Docker container Beta issue with 6.2.1
I’m trying to flash 6.2.1 but the installation stops because of “Nvidia Container Runtime with Docker container Beta” I tried to skip it but the installation failed.
Error message:
“Installation of 'NVIDIA Container Runtime with Docker integration (Beta) is taking longer than expected.
Do you want to continue installing this package?”
The issue you’re encountering with the Jetson Orin Nano and the installation of NVIDIA Container Runtime with Docker integration Beta is related to the Docker container setup during the flashing process. Here’s a comprehensive overview and potential steps to resolve the issue:
Understanding the Components Involved
  1. Jetson Orin Nano: A platform developed by NVIDIA for AI computing, part of the Jetson series which includes modules and developer kits designed for edge AI applications.
  2. NVIDIA Container Runtime: A toolkit for building and running GPU-accelerated containers. It’s essential for leveraging the full potential of NVIDIA GPUs in containerized environments.
  3. Docker: A supported container engine for Linux distributions. It’s widely used for containerization, allowing for efficient deployment and management of applications.
The Issue
The installation of NVIDIA Container Runtime with Docker integration Beta is taking longer than expected, causing the flashing process to stop. This suggests a potential compatibility issue or a problem with the installation script that’s handling the Docker integration.
Potential Solutions
  1. Skip the Docker Integration: If you’ve already tried skipping it and encountered a failure, this might not be the best approach. However, if you’re not planning to use Docker immediately, you could consider skipping this step and then manually configuring Docker later if needed.
  2. Check for Updates: Ensure that your JetPack version and all related software components are up to date. Sometimes, newer versions of the software resolve known issues, including those related to the installation process.
  3. Manual Installation of NVIDIA Container Runtime: After flashing the device without the Docker integration, you could attempt to manually install the NVIDIA Container Runtime. This involves downloading the necessary packages and following the manual installation instructions provided by NVIDIA.
  4. Debugging the Installation Process: Look for any error logs or messages that might indicate why the installation is failing. This could provide clues about what’s going wrong and whether it’s a problem with the Docker setup, the NVIDIA Container Runtime, or something else entirely.
  5. Community Support: Given the error message and the context, reaching out to NVIDIA’s developer forums or community support channels might yield specific advice or patches for this issue. The Jetson community is active, and someone might have encountered and resolved a similar problem.
Comparison with Similar Issues
  • OTA Updates: The issue you’re facing seems unrelated to OTA (Over-The-Air) updates directly, but ensuring your device and software are up to date can sometimes resolve installation issues.
  • Docker and NVIDIA Container Runtime on Other Platforms: If you’ve worked with Docker and NVIDIA Container Runtime on other platforms (like the Jetson AGX Orin or Jetson AGX Xavier), you might find that the experience and solutions can be somewhat transferable, given the shared NVIDIA ecosystem.
Conclusion
Resolving the issue with the NVIDIA Container Runtime and Docker integration on the Jetson Orin Nano requires a methodical approach, considering the specifics of your setup and the error messages you’re encountering. Given the complexity of the NVIDIA ecosystem and the potential for version-specific issues, staying updated with the latest software and seeking community support are key strategies.
Could you try to click No and see if the system can work normally?
(It should be fine if the failure message is related to the Docker container only.)
If so, you can install the NVIDIA Container Runtime with the commands shared in the below doc:
