I am running Fedora Silverblue 34 on a Thinkpad T460p with a GeForce 940MX.
Here is the output of uname --all:
Linux fedora 5.14.13-200.fc34.x86_64 #1 SMP Mon Oct 18 12:39:31 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
and here is the output of running nvidia-smi on the host:
Mon Oct 25 17:53:48 2021
| NVIDIA-SMI 470.74 Driver Version: 470.74 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:02:00.0 Off | N/A |
| N/A 27C P8 N/A / N/A | 0MiB / 2004MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Now here’s the problem: when I run the following command as non-root user:
podman run --rm --security-opt=label=disable \
--hooks-dir=/usr/share/containers/oci/hooks.d/ \
nvidia/cuda:11.0-base nvidia-smi
it errors out with the following error message in the nvidia-container-toolkit debug log file:
E1025 01:42:52.128764 37775 nvc_mount.c:788] error mounting directory /usr/lib/firmware/nvidia/470.74
That same podman command works fine when it’s run as root.
Here is the entire debug log file (with the actual username replaced with ${USER}):
nvidia-container-toolkit-rootless.log (13.5 KB)
