I would like to use NVIDIA DALI library to replace my current image pre-processing pipeline written in TensorFlow.
Currently I have the following code that applies random contrast distortion with the probability 0.5:
def random_contrast(image, lower=0.5, upper=1.5, prob=0.5, seed=None):
random_value = random_float(seed=seed)
image = tf.cond(tf.greater(prob, random_value),
lambda: tf.image.random_contrast(image, lower=lower, upper=upper, seed=seed),
lambda: image)
return image
The corresponding Contrast op (https://docs.nvidia.com/deeplearning/sdk/dali-developer-guide/docs/supported_ops.html#contrast) from DALI allows me to randomly alter the image contrast:
class MyPipeline(dali.pipeline.Pipeline):
def __init__(self, ...):
self.input = dali.ops.TFRecordReader(...)
self.random_contrast_value = dali.ops.Uniform(range=[0.5, 1.5])
self.random_contrast = dali.ops.Contrast()
def define_graph(self):
# Read images and labels
inputs = self.input(name="Reader")
images = inputs["image/encoded"]
labels = inputs["image/class/label"].gpu()
# Decode and augmentation
images = self.decode(images)
images = self.resize(images)
images = self.random_contrast(images.gpu(), contrast=self.random_contrast_value())
return (images, labels)
But this will apply the distortion to every single image. How can I make the operation being called only with 50% probability?
