Hi all,
I am using Dali 0.15 TFrecordPiepline as a substitute to tf.Data. However i cannot return a list of images from define_graph() function. I can get a pair of image-label from the define_graph() as they can be converted to a Dali-Edge Reference object but the same is not possible for multiple images from the same TFRecord. Also I need to perform a set of tensor operations on Label without converting it explicitly to a numpy array.
Am i missing something in define_graph() or the Pipeline?
