hi,
coming Metropolis microservices forum, https://forums.developer.nvidia.com/t/docker-pull-access-denied-for-analytics-stream/278858/7
I get the following error:
docker run --rm --gpus all nvidia/cuda:12.2.0-base-ubuntu20.04 nvidia-smi
docker: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as ‘legacy’
nvidia-container-cli: initialization error: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory: unknown.
Otherwise docket work ok like the following command:
docker compose -f foundational/mdx-foundational.yml -f mtmc-app/mdx-mtmc-app.yml --profile playback down
[+] Running 22/22
✔ Container mdx-elasticsearch-curator Removed 0.0s
✔ Container mdx-import-calibration-output Removed 0.0s
✔ Container mdx-calibration-toolkit Removed 0.0s
suvasis
