NVidia Drive Detailed Specs
DRIVE OS Version: 7.0.3
Issue Description: NVidia Drive Thor Detailed Specs
I was wondering if there’s a detailed NVidia Drive Thor spec sheet anywhere that breaks things down similarly to this one for the T5000 and T4000 Thor’s:
or this:
I’m guessing the NVidia Drive Thor chip is a T5000 with 64 instead of 128 GB of RAM but I just wanted to double check (for purposes like determining the compute capability, number and type of cuda and tensor cores, etc.).
Thanks,
Rich
Dear @rich.frederiksen ,
Could you check specifications at DRIVE AGX Autonomous Vehicle Development Platform | NVIDIA Developer and https://developer.download.nvidia.com/drive/docs/nvidia-drive-agx-thor-platform-for-developers.pdf
It doesn’t look like those links contain any details on the cuda/tensor core count or the compute capability number .
It has CUDA 12.8 with compute capability 10.1. GPU has 2560 CUDA cores and 96 5th gen Tensor cores
nvidia@tegra-ubuntu:~/cuda-samples/cuda-samples/build/Samples/1_Utilities/deviceQuery$ ./deviceQuery
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Thor"
  CUDA Driver Version / Runtime Version          12.8 / 12.8
  CUDA Capability Major/Minor version number:    10.1
  Total amount of global memory:                 15018 MBytes (15747514368 bytes)
  (020) Multiprocessors, (128) CUDA Cores/MP:    2560 CUDA Cores
  GPU Max Clock rate:                            1575 MHz (1.58 GHz)
One follow up question is the 15018 MB memory total the maximum memory that can be used for CUDA models/data on the device?
Thanks,
Rich
